Old 05-31-2012, 10:29 AM   #1
Blower motor runs constantly.
Hi, I have an American Standard Freedom 80 series furnace. The blower motor stays on constantly even when the thermostat is turned off. Any suggestions as to the problem would be welcome.
Thanks.
pnj618 is offline   Reply With Quote
Old 05-31-2012, 10:37 AM   #2
I leave my blower running all the time on purpose, to circulate & filter the air and to help even out the warmer/cooler rooms and upper/lower floors, so this isn't necessarily a bad thing.
First thing to check is obviously the simple thing, and that's to see if your fan switch (not the heat/air/off switch) is turned to "on" vs "auto" (I have too assume you already checked that but sometimes the simple answer is the solution). If not, maybe there's a problem with the thermostat. The thermostat, or the fan switch in the thermostat, could be bad. Or possibly some wires are crossing/touching behind the thermostat.
(Disclaimer: I'm not an HVAC tech, I just had this problem before at home and it was a bad thermostat)
pucks101 is offline   Reply With Quote
The Following User Says Thank You to pucks101 For This Useful Post:
pnj618 (05-31-2012)
Old 05-31-2012, 12:25 PM   #3
If all items mentioned by pucks101 are OK, the next thing to check wil be your control board. it is expensive, let's hope you won't have to go that far.
clocert is offline   Reply With Quote
The Following User Says Thank You to clocert For This Useful Post:
pnj618 (05-31-2012)
Bryant Plus 90 - No Blower Ducaticorse HVAC 11 10-16-2012 09:39 PM
Trane xe 90 furnace blower running constantly. sshaneparsons HVAC 4 12-08-2011 11:50 PM
Blower fan runs constantly epowerfan HVAC 65 12-06-2011 07:57 AM
need help/advice with a blower motor that runs constantly in a old bryant GetYourShineBox HVAC 0 07-27-2010 07:29 PM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 10:08 PM
