Blower Motor Replacement Question - HVAC - DIY Chatroom Home Improvement Forum
Old 06-20-2013, 01:25 PM   #1
Hello,
I have an older Trane XL90 system that I believe the squirrel cage motor has gon out on. The motor will run for 10 minutes or so then just stop spinning and buzz. Funny thing is that if I remove it from the air handler it will run fine but if it comes in contact with it, it will stop running and just buzz. Also it give a little shock if you touch it while running outside the air handler. So am I safe to assume it is a bad motor or is it just the capacitor? Also what was the original motor for this unit? The one I have in it now is GE# 5KCP39KG - N691S in bold, specs: 1/2HP - 115V - 60HZ - 9.3 AMPS - 1375 RPM. The Grainger rep I called said that he didnt have a generic replacement for this motor and said he thought the motor for this unit was a 1/2HP 1075 RPM with 9.0 amps? Any help appreciated my wife and three year old daughter are growing inpatient and hot lol!
dc2434 is offline   Reply With Quote
Old 06-20-2013, 01:55 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,818
it is a 1/2 hp motor but most of the Trane units I see don't take a generic motor due to the mounting bracket Trane uses. Try americanhvacparts.com. or a local Trane dealer. it may be the capacitor but you a need a tester for it or just try a new one. 95%-98% of the time it is the motor. If it is a higher speed 1375 motor then you must get it from Trane for the extra airflow.
Old 06-20-2013, 02:11 PM   #3
Can I replace the 1375rpm motor with a 1075? I have one that is 9.0 amp 1/2hp and 1075 rpm. Would this require a different capacitor? Also any idea what is causing it to work outside the furnace but "ground out" and stop working (only bzzing) when it comes in contact with the furnace? Thanks in advance!
Old 06-20-2013, 02:59 PM   #4
Hvac Pro
yuri's Avatar
Originally Posted by dc2434 View Post
Can I replace the 1375rpm motor with a 1075?May be 2 slow and cause the furnace 2 overheat and the Ac 2 freezeup from not enough airflow I have one that is 9.0 amp 1/2hp and 1075 rpm. Would this require a different capacitor?Don't know wood have 2 look at the motor specs 2 find out Also any idea what is causing it to work outside the furnace but "ground out" and stop working (only bzzing) when it comes in contact with the furnace? Inside the furnace it has 2 work harder against the resistance of the ductwork, outside it can freewheel, if it is shocking U then it is dangerous 2 you and your familyThanks in advance!
Tags
blower motor , trane
Heat comes on but blower never does aczer HVAC 12 02-13-2011 06:57 AM
Help with furnace blower problem Spydey HVAC 6 12-15-2010 08:18 PM
Blower shuts off even when set to 'on' fetzer85 HVAC 1 07-05-2010 11:48 AM
Ruud gas pack kills 2nd induced draft blower?? TurningWorm HVAC 2 01-31-2009 11:21 PM
