Blower Motor Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 12-03-2009, 10:47 PM   #1
Lighting Store Owner
Blower motor problem
My blower motor will not run from a dead stop. If I manually turn the motor and turn on the furnace everything it ok. The motor is a 4m100 Dayton if that makes any difference. I know the motor is good because it is new. Please help.
Im moving on to finishing the basement bathroom next!
noco is offline   Reply With Quote
Old 12-04-2009, 05:53 AM   #2
An old Tradesmen
Rewards Points: 6,098
Did they old motor do the same thing.
Did you also get a new capacitor, or are you reusing the old one.
Old one may be bad. Which means old motor might have been good.
Old 12-04-2009, 01:41 PM   #3
I just learn'd that and am getting a new capacitor right now. Ill let you know how it goes.
Old 12-04-2009, 04:52 PM   #4
That new cap almost certainly will fix it.
Old 12-04-2009, 05:58 PM   #5
Another lesson learned, don't feel bad it happens to all of us.
You still saved a buck or two.
SULTINI is offline   Reply With Quote
Old 12-04-2009, 08:20 PM   #6
DIY psychology
Usually the DIYer replaces the least costly, easiest-to-replace component first, regardless of the likelihood that it is the problem.
You did the reverse.
Why?
Old 12-04-2009, 11:47 PM   #7
Im new to the whole diy thing. Im just handy enough to be dangerous. I like the sport of it. Ive never tried to fix a furnace before. Yes I spent a few more buck but when it happens again I will have the lessons learned and will do better the second time. And yes the cap was the problem. I have an extra motor if anyone needs one. 4m100g and a bad cap.
Old 12-05-2009, 03:53 AM   #8
Why?
because he has been reading all your posts and knew if he did something against the statistics it would drive you nuts yoyziey
How's hagin' O one of excess gray matter?
hvaclover is offline   Reply With Quote
Old 12-05-2009, 08:12 AM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 1,102
A dying capacitor will overheat and shorten the life of your old motor so don't feel too bad. You may need the new one soon.
Old 12-05-2009, 09:23 AM   #10
Great chatroom by the way! Thanks for the help even though I am a little late. Ill know where to go the next time.
Old 12-05-2009, 12:26 PM   #11
Old 12-06-2009, 11:35 PM   #12
Ok so the blower motor is working... When the motor turns on it does it twice so to speak. On - Off - On - Run. It happens quickly less than a second.
Comfortmaker blower intermittent problem jh44ny HVAC 12 07-31-2011 07:41 PM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 07:57 AM
Acceptable Blower Vibration John_NH HVAC 15 11-21-2010 01:49 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 05:00 PM
