Old 06-22-2012, 04:52 AM   #1
Blower motor problem
The blower motor MOT6001 is 14 months old. When the hvac turns it on, it will run counter clockwise as it should, but at times it runs clockwise and the evaporator core freezes up. can this problem be fixed without replacing the motor?
ROY KLINE is offline   Reply With Quote
Old 06-22-2012, 06:19 AM   #2
JJboy's Avatar
Put a paper in from of the return grid, make sure the return is sucking air. looks like low refrigerant
Sent from my iPhone using DIY Forum
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-22-2012, 09:17 AM   #3
I would say to replace the motor capacitor.
Its my understanding that the motor capacitor serves to give the motor a little bit of a push at startup. other wise, with alternating current, the motor just wiggles back and forth as the current alternates. The cap give give the motor a little push (in the correct direction) and after that momentum keeps it going. again just my layman's understanding, but I would bet money on a bad capacitor. Change the cap for a new one with the same capacitance and same or above "working voltage". be sure to mark the wires or take a really good couple of pictures of the old wiring!!!!
bobinphx is offline   Reply With Quote
Bryant Plus 90 - No Blower Ducaticorse HVAC 11 10-16-2012 09:39 PM
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 09:06 AM
Blower NOT continuously ON on Bryant 310AAV rational HVAC 5 08-15-2011 09:44 PM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 02:21 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
