Blower Motor Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 03-31-2013, 09:49 PM   #1
Question
Blower motor not working
My blower motor went out (I thought) and I installed a new one with new capacitor. I have both green lights light up and not blinking for codes. furnace is lighting up no problem. Thermo glows, fire lights and just no blower and also no damage to control board.
Any thoughts?? Many thanks ahead of time.
tahoesnowman is offline   Reply With Quote
Old 03-31-2013, 10:12 PM   #2
how
Rewards Points: 1,104
Furnace brand and model helps.
How do you know there is no blower control damage?
Have you 120V from the board to the motor after the furnace heats up?
Do you have a summer fan switch/ a connected thermostat fan control or a method of turning on your fan.
Does the motor turn on when you jumper 'R" to "G" on your low voltage stat terminals on the board?
If your furnace heats up without the blower coming on, it should limit out and give you a blinking limit code.
how is offline   Reply With Quote
Old 03-31-2013, 11:02 PM   #3
Rheem RGLG 05NAUER, I am assuming that there is no damage to the board because I wasn't getting any blinking code. (But you know what happens when you assume, sometimes your wrong...) I do have a fan only setting and the motor does not start when I jumped R to G. I am looking for my meter to test but can find it anywhere.
Old 04-01-2013, 01:34 AM   #4
how
Either the furnace motor has been incorrectly connected to the board
(double check that the motor is connected to the heat power tap on the board/ that the right lines were connected to the capacitor and that the motor neutral was connected to the board neutral)
or the board is faulty.
If your main burners ran for 5 minutes and then shut themselves off, with the blower never coming on, a correctly working board should have at least given you a limit led code.
Old 04-01-2013, 04:46 PM   #5
Rewards Points: 582
agree with how....make sure motor is wired right to control board if it is then most likley its a bad control board....you said it has two green lights i think thats a much older board 12-16- yrs old ..but i could be wrong... ben sr
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
blower not working on heil heat pump jaw HVAC 0 10-31-2011 08:44 AM
Blower cycling and vibration whatshappening HVAC 1 02-09-2010 04:48 AM
Help - I need my humidifier working when blower is on, not just heat canuck88 HVAC 15 01-02-2010 03:31 AM
Lennox 12 GCS blower not working dickermt HVAC 4 12-27-2009 06:00 PM
