Blower Motor Not Starting - HVAC - DIY Chatroom Home Improvement Forum
Old 02-04-2011, 12:58 PM   #1
My blower motor does not run when the thermostat calls for heat. The motor does run when the thermostat is set to heat off and the fan is set to on. I assume this means the problem is likely the blower motor thermostat. but how do I find that thermostat and test it?
howard687 is offline   Reply With Quote
Old 02-04-2011, 11:38 PM   #2
Rewards Points: 460
You need to provide more detail. Model # etc.
If there's an draft inducer fan, does it come on first? Does flame igniter glow? Do you get burners to light?
You might just need to clean flame sensor located near one of the burners. Read Yuri's advice and see his pics by searching 'flame sensor'.
diyorpay is offline   Reply With Quote
Old 02-07-2011, 02:31 PM   #3
need more info, what is the brand and model number of furnace? how old is it the unit? since you say it doesn't even run with thermostat in on position, then its probably the motor itself or whatever controls it. Which may be a circuit board, relay, or fan temp. switch.
GhostRider96 is offline   Reply With Quote
Bryant 355MAV furnace and A/C blower not starting rajar2 HVAC 39 11-05-2015 02:03 PM
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 02:21 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 05:00 PM
