Blower Motor Not Running - HVAC - DIY Chatroom Home Improvement Forum
Old 07-05-2010, 01:09 PM   #1
blower motor not running
My Daughter has a Goodman A18-00 AC system. The blower motor will not run and it will trip the breaker about a minute after being rest.
The compresser is running outside and the cooling seems to be OK, just the blower fan is not running. The motor is not ceased up. Could it be the condenser on the blower or a bad thermstate?
Thanks in advance for your help!
Bill
grandpabill is offline   Reply With Quote
Old 07-05-2010, 07:19 PM   #2
An old Tradesmen
Rewards Points: 6,476
Doubtful its the thermostat if its blowing a line voltage fuse.
Could be the motors capacitor, or the motor itself.
Old 07-07-2010, 11:13 AM   #3
Smile
I bought a new capacitor and installed it and everything is working well. Thanks you very much for the reply.
One more question, the only capacitor the shop had was a "run" capacitor. I've seen posts here that there is a difference between "start" and "run". Is this correct? and if so should order and install a start capacitor?
Thanks Again
Bill
Old 07-07-2010, 12:32 PM   #4
Rewards Points: 338
if it was designed with just a run capacitor, that's all it should need. a start capacitor is different and uses a relay to give the motor winding extra "juice" on startup to get it going, then it shuts off and the run capacitor gives it constant juice while it is running.
NitroNate is offline   Reply With Quote
Old 07-07-2010, 12:44 PM   #5
Thanks...that makes sense!
BK
Old 07-07-2010, 01:03 PM   #6
An old Tradesmen
Residential blower motors don't use a start cap. They only use a run cap.
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 02:21 AM
Inside Blower motor keeps running crawlerchris HVAC 1 12-19-2009 09:01 PM
RPJ2 Blower fan will not stop running number22 HVAC 8 07-19-2009 06:27 PM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 10:08 PM
