Blower Motor Not Kicking On - HVAC - DIY Chatroom Home Improvement Forum
Old 02-22-2011, 10:03 PM   #1
When turning the thermostat fan position to on, the blower does not come on. Sometimes it works, and sometimes it doesn't. The problem first occured a few weeks ago, when we woke up and the house was freezing. My husband wiggled the wires and it started working again, and functioned for about 3 weeks. It stopped again yesterday, again wiggled the wires and it was operational for 24 hours.
Now it is out again and nothing seems to be "fixing it". Any idea what it could be and why it is an intermittent problem? Any help would be appreciated.
DnLStorms is offline   Reply With Quote
Old 02-22-2011, 11:47 PM   #2
JJboy's Avatar
You need to check or substitute the motor run capacitor. If the capacitor is good, about the only thing left is the motor or wires connections.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 02-27-2011, 09:13 PM   #3
Well, depending on what wire he wiggled, it could be a loose tstat wire, the tstat, or if you have a seperate blower speed for fan only it could be the motor wire. Does the fan run ok in the cooling mode?... in the heating mode?
Poppyloppy is offline   Reply With Quote
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Blower motor not kicking on??? walds11 HVAC 19 04-11-2010 10:27 AM
Blower not kicking in Appalachian HVAC 2 12-10-2009 06:40 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 04:00 PM
