Blower Motor Noise - HVAC - DIY Chatroom Home Improvement Forum
Old 11-08-2010, 09:17 PM   #1
Blower motor noise
Hey guys nice forum you have here..
Im having a small problem I hope you can help me with. I had about a year and a half ago installed a rheem 4 ton a/c unit model RHLLHM4821JA with x13 motor. Now for the first 9 months everything was perfect. But as time went on the blower motor got more and more noisy. I replace filters about every 1.5 month. Now if I pulled the filter out it will completely quite itself down.
As of late though the blower noise is horrendously loud, I don’t want to run it without a filter as im scared of clogging up the coil, even with the cover open the motor makes noise, is like a vibrating noise but the motor spins freely with no play and theres nothing loose or toucing. I changed the wiring of the motor from tap 4 what it was wired from the factory to tap 2 which is low for a 3.5 ton unit and it has quieted it down 85%. But im worried this might cause a problem with air flow acrros the coil, the return is pretty open, the door pictured below and two 24 x 16 vents on both sides of the wall.
Other relavant info , my house is 1600 sq ft, I live in Miami, florida.
heres a picture of the setup and return, filter is on the bottom, door open or closed makes no difference.
gsracer is offline   Reply With Quote
Old 11-08-2010, 09:46 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
My first question is what size a/c did you take out?
As far as a 4 tn on a 1600 sq ft house, well are you hanging meat
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 11-08-2010, 10:44 PM   #3
We bought the house forclosed and all the previous stuff had been stolen so it was a new installation.
As for hanging meat lol, its florida so its pretty hot, we keep the thermo at 74 during the day and 69 at night.
Old 11-09-2010, 06:31 AM   #4
Have you been oiling the blower motor? Many need a few drops each season on the bearings. Often little capped tubes travel to motor bearings.
diyorpay is offline   Reply With Quote
Old 11-09-2010, 06:03 PM   #5
An old Tradesmen
Rewards Points: 7,414
Its an Z13. No oiling needed.
Old 11-09-2010, 06:05 PM   #6
An old Tradesmen
Sounds like your supply duct may be a bit undersized.
Not sure on their air handlers. But some Rheem furnaces have a shipping bracket that needs to be removed. Check if your air handler has a shipping bracket that should have been removed.
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Blower shuts off even when set to 'on' fetzer85 HVAC 1 07-05-2010 11:48 AM
Blower cycling and vibration whatshappening HVAC 1 02-09-2010 04:48 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 04:00 PM
