-   -   Blower motor noise (http://www.diychatroom.com/f17/blower-motor-noise-86222/)
gsracer 11-08-2010 09:17 PM
Blower motor noise
Hey guys nice forum you have here..
Im having a small problem I hope you can help me with. I had about a year and a half ago installed a rheem 4 ton a/c unit model RHLLHM4821JA with x13 motor. Now for the first 9 months everything was perfect. But as time went on the blower motor got more and more noisy. I replace filters about every 1.5 month. Now if I pulled the filter out it will completely quite itself down.
As of late though the blower noise is horrendously loud, I don’t want to run it without a filter as im scared of clogging up the coil, even with the cover open the motor makes noise, is like a vibrating noise but the motor spins freely with no play and theres nothing loose or toucing. I changed the wiring of the motor from tap 4 what it was wired from the factory to tap 2 which is low for a 3.5 ton unit and it has quieted it down 85%. But im worried this might cause a problem with air flow acrros the coil, the return is pretty open, the door pictured below and two 24 x 16 vents on both sides of the wall.
Other relavant info , my house is 1600 sq ft, I live in Miami, florida.
heres a picture of the setup and return, filter is on the bottom, door open or closed makes no difference.
http://img.photobucket.com/albums/v3...r/bc0d07d2.jpg
Plumber101 11-08-2010 09:46 PM
My first question is what size a/c did you take out?
As far as a 4 tn on a 1600 sq ft house, well are you hanging meat
gsracer 11-08-2010 10:44 PM
We bought the house forclosed and all the previous stuff had been stolen so it was a new installation.
As for hanging meat lol, its florida so its pretty hot, we keep the thermo at 74 during the day and 69 at night.
diyorpay 11-09-2010 06:31 AM
Have you been oiling the blower motor? Many need a few drops each season on the bearings. Often little capped tubes travel to motor bearings.
beenthere 11-09-2010 06:03 PM
Its an Z13. No oiling needed.
beenthere 11-09-2010 06:05 PM
Sounds like your supply duct may be a bit undersized.
Not sure on their air handlers. But some Rheem furnaces have a shipping bracket that needs to be removed. Check if your air handler has a shipping bracket that should have been removed.
