Blower Motor Humming - HVAC - DIY Chatroom Home Improvement Forum
Old 12-26-2012, 05:10 PM   #1
Blower motor humming
This morning I noticed that the blower on the furnace was not working properly... it hums fairly loudly but doesn't spin at all. I was thinking it's either the capacitor or the motor, but I can't find a capacitor anywhere in the furnace.
Will I have to install a capacitor in order to replace the motor? Or can I just match the motor at a parts store and simply replace the old one? The furnace is ~30 years old and has a 3 speed motor.
k4ppa is offline   Reply With Quote
Old 12-26-2012, 05:20 PM   #2
An old Tradesmen
Rewards Points: 6,870
New motor, new capacitor. Post pics of motor, specially its data plate. or post the info on the data plate.
Old 12-26-2012, 05:35 PM   #3
Rewards Points: 616
capacitor must match new motor..... it is possible all yo need is a capacitor though .....
carmon is offline   Reply With Quote
Old 12-26-2012, 07:12 PM   #4
I don't think the furnace has a capacitor. As far as I understand it should be mounted on the outside of the blower housing (connected along the blower motor wiring)... but there is nothing of the sort. Would I need to install a capacitor to replace the motor?
This is a picture of the motor label:
Old 12-26-2012, 07:24 PM   #5
An old Tradesmen
If it only has 4 wires coming out of it, then its a shaded pole motor, no capacitor.
The Following User Says Thank You to beenthere For This Useful Post:
k4ppa (12-26-2012)
Old 12-26-2012, 07:53 PM   #6
Thank you for the clarification. The motor does indeed have 4 wires coming out of it.
Anyone have any tips as far as removing the motor shaft from the fan?
I loosened the bolt on the shaft and got it to move quit a bit with the aid of a hammer and a little wd40... but the very last 2 inches or so will not budge.
Old 12-26-2012, 08:28 PM   #7
An old Tradesmen
Hammer is not a good thing to use on the shaft as it tends to mush the shaft out so that the wheel won't slide over it. A hub puller is what I use.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (12-26-2012), k4ppa (12-26-2012)
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 08:06 AM
Blower cycling and vibration whatshappening HVAC 1 02-09-2010 04:48 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
