Old 03-06-2012, 10:41 PM   #1
blower motor on the furnace keeps running.
what causes the blower motor to keep running on the furnace?
esidros is offline   Reply With Quote
Old 03-06-2012, 10:43 PM   #2
What could be the problem?
Old 03-06-2012, 10:46 PM   #3
GC/Master Plumber/Mech
Thermostat fan selector set to the ON position
High limit tripped
Roll out limit triped
When was the last time you replaced the filter?
Brand and model would help
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-06-2012, 10:47 PM   #4
Professional
fan switch on t-stat set to ON instead of auto. Or a high limit is tripped due to low airflow.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-06-2012, 10:48 PM   #5
Thanks for the back-up. LOL
Old 03-06-2012, 10:51 PM   #6
Professional
yep, you got me by a few seconds
IT IS WHAT IT IS
Old 03-06-2012, 10:56 PM   #7
how
Just to extend that list...
Thermostat wire cross connection between "R" & "G" /a sticking fan relay or if you are dealing with a furnace that's 25 years or older.. broken fan- limit control or a summer fan switch left on.
how is offline   Reply With Quote
Help diag. blower motor issue in Lennox furnace partsace HVAC 12 01-23-2012 03:59 PM
Carrier Weathermaker Gas Furnace - No blower for heat nerdbit HVAC 5 09-20-2011 11:31 PM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 02:21 AM
Luxaire furnace blower will not shut off danaugstin HVAC 1 10-06-2009 10:14 PM
furnace blower keeps running dmbrasket@hotmail.com HVAC 7 02-03-2008 04:57 PM
