Old 02-27-2012, 09:50 PM   #1
Lightbulb
Blower motor electrical puzzle, please help!
Hi guys, I am a newbie to this site, but I was hoping someone could help help me solve a slight issue that i am having. I am building a small paint booth for airbrushing, and am planning to use a 12 volt blower motor that I found from an unknown toyota car to exhaust the paint fumes through ducting out a window(I really want to use this fan because it has a sealed external motor). I tested the fan with a 10 amp battery charger which spun the fan fine, with plenty of air movement. I am currently trying to run the fan on AC power from a plain wall outlet in my house, but so far i have found nothing to do so. I tried a small AC to DC converter which didn't meet up to the amps needed because the fan didnt even stay in constant motion, next I tried a laptop adapter that put out 6 amps at 20 volts and had the same effect as the last. As of right now I am just trying to power the fan, but eventually would like to use a speed controller. If anybody has any tips as to how I can make this work, please help me out! I am very good with cars, but nothing close to an electrician. Thank you in advance for any and all advice!
motohead918 is offline   Reply With Quote
Old 02-27-2012, 10:01 PM   #2
GC/Master Plumber/Mech
Check out Radio Shack for a DC power supply. You will also be able to find a rheostat to control the speed of the fan.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
The Following User Says Thank You to Plumber101 For This Useful Post:
motohead918 (02-27-2012)
Old 02-27-2012, 10:05 PM   #3
Would you happen to know of any specs i should be looking for? I am thinking that the 10-12 amp range should get the job done, and thanks for the reply!
Old 02-27-2012, 10:12 PM   #4
I have seen some of the fan motors you are trying to use pull 12-13 amps.
I would look for a power supply with at least 15-20 amps and a high amp rated rehostat
Bryant Plus 90 - No Blower Ducaticorse HVAC 11 10-16-2012 09:39 PM
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 09:06 AM
Blower NOT continuously ON on Bryant 310AAV rational HVAC 5 08-15-2011 09:44 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
Blower motor puzzle Bakery Lady HVAC 0 08-19-2009 10:52 PM
