Blower Motor - HVAC - DIY Chatroom Home Improvement Forum
Old 12-05-2010, 01:51 PM   #1
blower motor
i have a g e blower motor 5kcp39gg it has a p211s after the # what does the p 211s mean and what is a replacement motor for it
rickey brewer is offline   Reply With Quote
Old 12-05-2010, 02:06 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
better information to ask you would be, what hp rating is the current one, what direction IE: clockwise or counterclockwise lead end? What size frame? What kind of mount it has IE: belly band or mounts are welded to motor? An universal would be the cheaper route as long as you know these answers....
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-05-2010, 02:20 PM   #3
blower motor
it goes a trean air handler it is 1/3 hp 208/230 volts f.l.amps are2.1 rpm 1075 it has a ban around it is removeable
Old 12-05-2010, 02:28 PM   #4
its in a trane air handler it is 1/3 hp 208/230volts fl amps 2.1 rpm 1075 it has a belly ban looking from the back of motor it is turning counterclockwise
Old 12-05-2010, 02:38 PM   #5
AKA HVACTECHFW
take your specs you have just told us and go to a motor shop, they can then point you in the direction of a replacement motor. You didn't state if there was an issue with your current one, I'm assuming so.... Have you checked for voltage to the motor or what type of problem are you having with it?
IT IS WHAT IT IS
The Following User Says Thank You to hvactech126 For This Useful Post:
rickey brewer (12-05-2010)
Old 12-05-2010, 02:42 PM   #6
motor is makeing noise when start up then runs fine
Old 12-05-2010, 02:45 PM   #7
AKA HVACTECHFW
Do you have a meter that checks capacitance? If so, start there. If not, a Capacitor would be a much cheaper way to start than a motor.
IT IS WHAT IT IS
Trane XL80 blower motor part number? keverino HVAC 17 01-10-2012 09:01 AM
nordyne e2eb-015ha blower motor jhw3_2005 HVAC 3 08-20-2010 02:29 PM
comfortmaker furnace; i've done the hard part by taking the blower motor out Hurell HVAC 2 06-05-2010 01:03 PM
Replaced motor blower now getting error 33 danny_isr HVAC 14 01-14-2010 02:35 PM
Inside Blower motor keeps running crawlerchris HVAC 1 12-19-2009 08:01 PM
