Blower And Ignitor Won't Shut Off! - HVAC - DIY Chatroom Home Improvement Forum
Old 04-07-2013, 07:25 PM   #1
Blower and ignitor won't shut off!
Hello,
I have a Coleman Evcon Model No. U17R30K. We had a thunderstorm a few nights ago, which caused an intermittent power outage. Now, the blower and the ignitor coil on our unit will NOT shut off. Although the ignitor stays on (glowing orange and hot), the blower is NOT blowing hot air.
I've set the thermostat to "Auto" and "Off", but the fan continues to blow. I've reset it, taken out the batteries, and completely disconnected the thermostat, but the fan and the ignitor coil still won't shut off. I've also, tried tripping the breaker switch "off" and "on", but no dice.
Air conditioning is working properly when set to "Cold". Thermostat functions properly, shutting off cold air at a preset temperature, but the fan continues to blow. Thermostat also works properly when set to "Heat", (I hear it clicking when set to specific temps), however, there is NO hot air. Even though the ignitor is constantly on.
The furnace circuit board light is a constant "Green", which indicates it's functioning properly. I followed the wiring diagram to the "limit switch" to try and reset it. There's a little red button on the "limit switch", but doesn't move when i try to press down on it with the tip of a screwdriver.
I disconnected the "ignitor" temporarily so i can continue to use the air conditioner, and I turn off the unit via the main switch before my wife and I leave for work. Please help me fix this thing
Thanks in advance!
johnhay is offline   Reply With Quote
Old 04-07-2013, 07:35 PM   #2
An old Tradesmen
Rewards Points: 7,826
A, that isn't a limit switch. Its a roll out witch.
B. Good chance the boar is shorted out.
Try disconnecting the white wire from the W terminal on the furnace board. If it still does it, its probably the board(relay stuck shut).
Old 04-07-2013, 07:41 PM   #3
Where is the limit switch on this unit?
Old 04-07-2013, 08:13 PM   #4
An old Tradesmen
Directly behind the gas valve.
Old 04-07-2013, 08:22 PM   #5
the one behind the gas valve looks identical to the pic i posted. does it have a manual reset button? and if it does, do you think resetting it might work?
Old 04-07-2013, 08:35 PM   #6
An old Tradesmen
Its auto reset. An HSI won't stick on because of a tripped high limit, nor because of a tripped roll out switch.
Old 04-07-2013, 08:43 PM   #7
thank you for the reply! and what is an HSI?
Old 04-07-2013, 08:46 PM   #8
An old Tradesmen
The thing that is glowing.
Old 04-09-2013, 11:22 PM   #9
Hot Surface Ignitor (glow coil)
Focused2 is offline   Reply With Quote
