Blower On Furnace Sometime Did Not Turn On. - HVAC - DIY Chatroom Home Improvement Forum
Old 06-15-2011, 01:15 PM   #1
Blower on furnace sometime did not turn on.
Blower motor checked turn freely, bad cap replaced, freon checked, condenser and evap coils cleaned.
If you catched the fan (blower motor) not turn on when ac first start, just turn ac off couple minutes and turn it back on, it will working fine. If you did not catched on time, it will frost the evap coil all the way to condenser.
This is a heat pump unit. It start doing it last summer, after I change out the cap, it working fine through the whole summer. Now it start doing it again.
Could it be the relay? Or the blower motor? Any help would be appreciated it.
max2k is offline   Reply With Quote
Old 06-15-2011, 01:27 PM   #2
JJboy's Avatar
Bad capacitor made in China
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 03:22 PM
Payne gas furnace - blower fan running continuously Ed40 HVAC 0 02-05-2011 02:19 PM
Furnace blower only runs VERY slow... tippet HVAC 12 12-04-2010 04:50 PM
Blower motor in old bryant furnace runs constantly GetYourShineBox HVAC 2 07-20-2010 07:49 PM
Need Advice on blower for furnace babijae HVAC 5 01-16-2009 10:38 PM
