Blower Fans Not Turning - HVAC - DIY Chatroom Home Improvement Forum
Old 01-13-2013, 03:40 PM   #1
blower fans not turning
Are the fans on the outside unit supposed to be turning when the blower inside the house is on?
jakesters is offline   Reply With Quote
Old 01-13-2013, 04:57 PM   #2
Rewards Points: 93
If the outside unit is a heat pump, and you are requesting heat then yes it should be turning unless it is in a defrost mode.
Also, you make have your fan inside set to ON instead of AUTO. In that case the fan inside the house will run continuously circulating the air even if you are not requesting heat (or cooling).
tls1 is offline   Reply With Quote
The Following User Says Thank You to tls1 For This Useful Post:
jakesters (01-13-2013)
Old 01-13-2013, 10:11 PM   #3
Yes this is a heat pump and the setting was set on Auto. Your advise was helpful and the unit may have been defrosting since the fans did begin to turn afterwards.
Thank you
blower problems with bryant furnace. blowerissue HVAC 4 03-14-2012 12:34 AM
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 09:06 AM
Carrier Weathermaker 9200 - Blower not turning on. bvijay HVAC 7 08-15-2011 08:04 PM
Condenser and Blower not turning on nEmEsIs15dead HVAC 11 08-09-2010 10:56 PM
Inside Blower motor keeps running crawlerchris HVAC 1 12-19-2009 09:01 PM
