Old 09-12-2009, 01:12 PM   #1
Question Blower Fan Won't Come On
Yesterday I noticed frost around my outside unit (split uint, furnace piece & blower upstairs). I thought maybe low freon, and read to turn the fan on alone to let it thaw in case the coil were frozen over. I let it do this for about 6 hours. (we left for awhile).
When we got back.. still no go. I noticed at this time no air was coming through the vents. I went upstairs and cracked open my unit, and there was NO ice on the coil left, BUT at this time I noticed the fan wasn't coming on at all.
I looked around on forums and read that you could test the thermostats by connecting the red to the green. Tried that, still no go, so I believe the thermostat is good. The breakers have all been set and reset. Last night while I was holding down the switch manually (wall switch that's closed when you take the side of the fan wall off, I suck at terminology), the unit kicked to life for about 5 seconds (until I let go of the switch to put the plate back on). It wouldn't fire back up again no matter what I did.
This morning I was reading and saw that the "block box with wires out both ends" was the relay and that maybe the issue. I'm not sure. I can hear the relay kick over, but nothing happens at that time. The little black box in mine is labeled transformer. Is that the relay? It gets very warm after the relay has clicked over.
Would it help if I posted a pic of the board? Or perhaps did some multimeter checks?
Thanks in advance!
MichaelKB is offline   Reply With Quote
Old 09-12-2009, 01:36 PM   #2
old pro
Post a pic of the board and the complete make, model and serial # of the furnace.
Old 09-12-2009, 08:40 PM   #3
Some of the pics are kinda big, hopefully it's what's needed!
Make/Model Info:
Board:
Schematic:
The Transformer I was talking about that gets hot when it's on (but still not spinning the fan):
Old 09-13-2009, 12:08 AM   #4
old pro
Check the pink 3 amp fuse on the board to see if it is blown. There is also a capacitor mounted on the fan housing for the motor and it may be faulty. You would need a capacitor tester to check it. Some multi meters can do that function. The relay is built inside the gray control board and the other item is your 24 volt transformer. Does the motor/fan spin easily by hand or is is stiff and seizing up?
Old 09-13-2009, 08:03 PM   #5
The motor turns very easily. And keeps on turning. It seems very well in shape. I took out the cap. and tried to measure with my multimeter, and couldn't get much a reading at all, so I'm thinking it's that. It's only $7 so I'm at least going to try and see if that does it. Thanks for the help!! I'll post my results (nobody is open today.. thank goodness it's cool and rainy out!)
Old 09-13-2009, 09:18 PM   #6
Yoyizit's Avatar
How hot does that 'former get?
no skin burn ever at 42°C(108°F)
burn in 30 sec at 54°C(129°F)
5 sec at 60°C(140°F)
1 sec at 71°C(160°F)
Keep the old cap; there's an easy way to check it with any voltmeter, a 9v battery and a Radio Shack 1 megohm resistor. Also, it wouldn't hurt to check the new one before you put it in.
Old 09-13-2009, 11:00 PM   #7
wannabe
have you checked for power at the blower motor when it was time for it to come on ?? I would do this b-4 I started replacing parts.. Could be bad board
kenmac is offline   Reply With Quote
Old 09-13-2009, 11:52 PM   #8
Look at the schematic: You see there are four tabs (heat, cool, spare1, and spare2). Remove one of the wires in the park position. Look at the schematic again, right below the hsir box, you will see two tabs (l1 and pr1) remove the wire in the pr1 tab. This will prevent the control board from energizing. Now plug one of the wires that was removed from the spare tab and insert it into the pr1 tab.
Push in the door switch. If the fan runs, you likely have a bad board. Now thats just internet advise. I am not there, and there is a possibility that something may be wrong with the transformer or something else that wasn't seen. But at this point you need to determine if the problem is within the load, or the control.
Flashheatingand is offline   Reply With Quote
Old 09-15-2009, 07:50 PM   #9
Flashheatingand, I'll give that a shot. I bought a new capacitor to give it a shot and it was no go. I still here the relay click but nothing happens.
Old 09-26-2009, 06:12 PM   #10
Thanks for the tip! It's not the blower motor.. it's running right now wired like you suggested for testing. Now I guess I know it's the relay/board?
Old 09-26-2009, 06:37 PM   #11
I noticed this says direct replacement for a bunch of models, and I found my model number in there (58PAV090). Would this be the part I need to get up and running?
http://www.thecoolingstation.com/ind...roducts_id=117
Old 09-27-2009, 10:24 PM   #12
Sorry Homey, your going to have to figure that one out on your own...
Old 09-27-2009, 10:31 PM   #13
lol.. man it's a hot night. I suppose running the spare to both the spot you told me (pr1) and the spot it was resting in would be a bad idea? I'm bout ready to rig it on for some sleep... lol
Old 10-31-2009, 03:42 PM   #14
I opened up my circuit board and took a look. Big black burn spot on my relay. If I can solder, and since it's only $1.30, is there any reason why I shouldn't fix it myself by soldering in the new part as opposed to buying the whole board for $195.00? The part is http://www.mouser.com/ProductDetail/...qY6CWmcjPlU%3D
Old 10-31-2009, 04:06 PM   #15
Yoyizit's Avatar
If your furnace relay really does run on DC you might need a coil transient suppression diode unless it is already in this Mouser relay.
More On This Topic
The thermostat on your wall that controls your HVAC system is the key to your comfort. Knowing how it interfaces with your heating and air conditioning system can help you stay comfortable during long, cold winters and hot, sweltering summers. A key part... Read More »
Nothing can ruin your summer or winter like finding you have no heat or air conditioning because your heat pump is malfunctioning. If you have to buy a new heat pump, an uncomfortable season can turn into an uncomfortable year. However, heat pumps are... Read More »
How to do a Blower Test
How to do a Blower Test by Expert Village
Hi! I'm Joshua Lindsey with CFM Building Science Solution. On behalf of Expert Village, we are going to be doing a blower door test on this home. So now it is asking me what ring, what flow ring I want to go with. On the fan here, this is ring A, B and C... Read More »
How to Install a Fan Relay
How to Install a Fan Relay by Expert Village
Hi I'm Doug. I work with twenty great guys in St. Louis at Doug Jenkins Custom Hot Rods, and we're going to do some work for you today on Expert Village. Now we're going to tame an octupus. We need to put in a fan relay. And we're just going to choose a... Read More »
If you've had trouble insulating your home from hot summer weather, you might consider investing in an attic fan. While air conditioning can help to cool air in the livable portions of your home, most attics do not have air conditioning. After hours of... Read More »
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 06:00 PM
Blower keeps cycling on and off simonb HVAC 1 01-17-2009 12:56 PM
Acceptable Blower Vibration John_NH HVAC 11 01-10-2009 05:35 PM
Comfortmaker blower intermittent problem jh44ny HVAC 10 10-05-2008 09:19 PM
Heat comes on but blower never does aczer HVAC 11 11-21-2006 04:37 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
