Blower Fan Wont Come On - HVAC - DIY Chatroom Home Improvement Forum
Old 08-04-2011, 05:08 PM   #1
Rewards Points: 33
Blower fan wont come on
I have a Carrier furnace Model FV4B electric heat pump and AC unit. The unit is 3 years old. Today, all of a sudden, the fan stopped running. The unit outside continues to run, and the thermostat says that it's running, but the fan just isn't going. I've replaced the batteries and reset the thermostat. I checked the 5A automotive type fuse on the board inside the furnace, and I've spun the blower fan by hand. It all checks out. Also, after checking the troubleshoting section in the owners manual for the thermostat, I checked the Y terminal in the furnace and there is a 24VAC present. Is there anything else I can check before I get a technician in to take over? Thanks in advance.
jools is offline   Reply With Quote
Old 08-04-2011, 05:27 PM   #2
HVAC Tech/Owner
Rewards Points: 604
that unit has a variable speed motor and requires a good tech to take care of it. If the airhandler has highvoltage and low voltage like you already checked, thats about all you can do.
Technow is offline   Reply With Quote
The Following User Says Thank You to Technow For This Useful Post:
jools (08-04-2011)
Old 08-04-2011, 05:32 PM   #3
Rewards Points: 6,652
+ MOTOR
- If motor is hard to turn manually, but turns freely, replace module.
- If motor does not run, check the components listed below according to their instructions.
- If motor runs in some operation modes and not in others, check for a good ground connection between motor ground lead and circuit board
screw marked "ground screw" and check the room thermostat and wiring harness according to instructions listed in Table 4.
- If motor does not stop running, remove the 7-pin plug from circuit board. If motor continues to run, replace motor. If motor stops running
after 2 minutes, it is either the circuit board or thermostat causing the problem. Test whether thermostat is at fault by disconnecting it from the
board.
+ CIRCUIT BOARD
- Check 5-amp fuse.
- Check for 230v between terminals M1 and M2. If no voltage is present, check power to board. 230-v power enters the board through the black
and yellow lead in the 12-pin plug.
- Check for 24v between SEC1 and SEC2. If no voltage is present, check the transformer.
- Check for burn traces or burnt components. If burn spots are present, replace board.
http://www.ahi-carrier.ae/download.a...ocs/cm_114.pdf
The Following User Says Thank You to gregzoll For This Useful Post:
jools (08-04-2011)
Old 08-04-2011, 05:49 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 92
should have at least 5 yr warranty on the motor and probably 10 so don't mess with it. call a Carrier tech.
The Following User Says Thank You to yuri For This Useful Post:
jools (08-04-2011)
Old 08-04-2011, 07:53 PM   #5
Rewards Points: 33
My PCB is slightly diferent from the one detailed in the manual you attached. But still a great help! I've checked everything up to the PCB, including transformers, and it all seems good. I've also tried jumping the R and G terminals at the thermostat to try and start the fan manually, but it's not coming on. I guess I'd better get a tech in...
Old 08-04-2011, 07:57 PM   #6
Rewards Points: 33
I'm not sure if this pertains or not, but I've been turning the AC off and on throughout this testing process via the thermostat, the "COOL ON" will flash for about 90 seconds whenever I turn the unit back on, it never used to do that... The compressor outside will not turn on until the flashing has stopped.
Old 08-04-2011, 08:11 PM   #7
What is the model & manufacturer of the thermostat?
Old 08-04-2011, 08:12 PM   #8
Rewards Points: 33
Also Carrier, Model TSTATCCN(HP)01-C
Old 08-04-2011, 09:29 PM   #9
30 year tech
hvac122's Avatar
Sounds like the thermostat has a time delay to stop short cycling.
hvac122 is offline   Reply With Quote
Old 08-04-2011, 09:30 PM   #10
Rewards Points: 33
So once it stops flashing, everything should function normally (When the unit is working properly anyway...)?
Old 08-04-2011, 09:56 PM   #11
Usually is a four minute delay.
jools (08-04-2011)
Old 08-04-2011, 09:59 PM   #12
Rewards Points: 33
Yeah it does stop flashing after a bit, but could this be related to the fan issue? Even after it stops flashing, I still can't get the blower to run up.
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 06:57 AM
Blower shuts off even when set to 'on' fetzer85 HVAC 1 07-05-2010 11:48 AM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 01:21 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
