Blower/fan Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 10-24-2013, 11:07 AM   #1
Rewards Points: 20
Blower/fan wiring
I would like to wire in a continuous fan. I have a modern Thermostat. the furnace is not wired for a continuous fan, though it has connectors. I thought I could run a 24 volt to the Camstat that controls the Fan ON. As I look at it, I think it will just turn the furnace on. What are options to wire in a fan only switch/relay, just to run on low.
thanks,
knickityknack
Blower/fan wiring-img_9198.jpg   Blower/fan wiring-img_6393.jpg   Blower/fan wiring-img_3739.jpg   Blower/fan wiring-img_0410.jpg
knickityknack is offline   Reply With Quote
Old 10-24-2013, 02:59 PM   #2
An old Tradesmen
Rewards Points: 7,746
Brand and model number of furnace would help. Also a pic of the controls on it.
Old 10-24-2013, 04:57 PM   #3
FClef's Avatar
Rewards Points: 160
Continuously running fans in a furnace is great if done correctly. Done correctly. You must be able to control the speed of the fan because the fan will be running constantly and you do not want cold drafts coming from it, in fact you barely want to feel that air.
"Human beings can always be relied upon to assert, with vigor, their God-given right to be stupid"
Dean Koontz - Seize The Night
FClef is offline   Reply With Quote
Old 10-26-2013, 01:03 AM   #4
Rewards Points: 20
Add blower/fan only to furance
This is an old Wesco Furnace.
Education please; Why does it have a 24 volt converter and still plug in to a 24 volt 24 DC relay. Aren't most of these AC
Please if you want more pictures or info let me know.
Have Fun
thanks,
knickityknack
Blower/fan wiring-img_9198.jpg   Blower/fan wiring-img_7259.jpg   Blower/fan wiring-img_6580.jpg   Blower/fan wiring-img_6393.jpg   Blower/fan wiring-img_0410.jpg
Blower/fan wiring-img_2061.jpg
Old 10-26-2013, 03:40 AM   #5
Rewards Points: 1,192
Have fun? Coste Plente for free advice.
bobelectric is offline   Reply With Quote
Old 10-26-2013, 10:45 PM   #6
Rewards Points: 20
Hi Beenthere, any idea on wiring in a fan only relay/switch. old Wesco furnace.
I have picture up on another thread.
thanks,
Knickityknack
Old 10-26-2013, 11:05 PM   #7
An old Tradesmen
Diagram shows you have an A/C relay. Do you.
Old 10-26-2013, 11:19 PM   #8
Rewards Points: 20
I must. however this picture of a relay confused me.
Blower/fan wiring-img_4806.jpg
Old 10-26-2013, 11:24 PM   #9
An old Tradesmen
Why. It works doesn't it.
Old 11-06-2013, 12:44 PM   #10
Rewards Points: 20
DOES ANYONE KNOW!??? How to add a Fan/only relay/switch to a furnace? What are the different options? Lets give advise about how to do the task at hand? All the advise that is provided and statements are great, but there are no answers to the question.
Old 11-06-2013, 01:35 PM   #11
PoleCat's Avatar
Rewards Points: 1,652
Post a pic of the schematic and one of the indigenous HVAC wizards will be able to help you.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 11-06-2013, 05:24 PM   #12
An old Tradesmen
Hard to help. When you don't get an answer to the questions you need answered, to give the help.
Old 11-09-2013, 09:48 AM   #13
Rewards Points: 20
i was concerned because it went from AC to DC, Didn't think that was right with out running through a converter. But, Yes, Everything works on the furnace, including, AC converter and relay. Here are pictures of the wiring diagrams. Looks like the G wire goes to the AC relay (RBM -91) attaching to the other side of the coil. I don't have Air Conditioning.
I just would like to run on low speed.
thanks, have a great weekend.
Blower/fan wiring-img_1854-1-.jpg
Old 11-09-2013, 10:49 AM   #14
Rewards Points: 20
right side up!
Blower/fan wiring-img_1854.jpg   Blower/fan wiring-img_1854-1-.jpg
Old 11-09-2013, 03:41 PM   #15
An old Tradesmen
Originally Posted by knickityknack View Post
right side up!
The middle relay of the upper pic, is the fan relay. You need to connect the wire from it to where teh wire from the thermostat's G terminal connects.
Help with wiring issues on a newly purchased house ThatGuy Electrical 13 01-17-2012 10:51 AM
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
