Old 04-16-2007, 07:38 PM   #1
Question
Blower fan runs continuously
Last year, I installed a new thermostat on my old HVAC system and a few months later, installed a new Condensor unit and Gas Heater & Blower with the already new-ish thermostat. I did not purchase from a retailer or distributor and had a friend of a friend (licensed - on the side) install the entire thing. Problem is, the blower fan now runs continuously, whether heating or cooling. It drives me nuts! Do I have to re-wire the thermostat? If so, where do I find out how to re-wire? I've tried to read the Gas Heater manual and it's gobbledygook....HELP!
mgeller is offline   Reply With Quote
Old 04-16-2007, 08:52 PM   #2
model number andx make as well as serial # please
harleyrider is offline   Reply With Quote
Old 04-16-2007, 09:05 PM   #3
Diesel Fitter
is the fan switch in auto?
mikemy6 is offline   Reply With Quote
Old 04-16-2007, 09:21 PM   #4
Smile
Thanks, Mikemy6 - yes, the fan is switched to auto at the Thermostat.
HarleyRider - I'll go and check the numbers and post them...do you want the thermostat and Heater/blower?
Old 04-16-2007, 09:26 PM   #5
Diesel Fitter
summer switch on unit?
Old 04-19-2007, 10:27 PM   #6
i suggest you disconnect the green wire on the therm, if the fan stops running its a thermostat issue. if the fan still runs, then dissconnect the green wire at the air handler, if the fan stops then the problem is the low voltage wire has shorted out between wires. if the fan still runs then the issue is the air handler.
jmosh is offline   Reply With Quote
Heat comes on but blower never does aczer HVAC 12 02-13-2011 07:57 AM
blower runs, with no heat captjack HVAC 6 12-14-2010 03:15 PM
AC Unit Continuously Runs - yet it is cooling reefland HVAC 4 06-17-2007 08:04 PM
weatherking furnace blower runs continuously rayborj HVAC 4 12-08-2006 03:23 PM
Heat/AC blower runs continuously. hdd HVAC 1 01-16-2006 01:00 PM
