Blower Fan Continues To Run When Ac Is Off Or On - HVAC - DIY Chatroom Home Improvement Forum
Old 04-08-2012, 09:32 AM   #1
blower fan continues to run when ac is off or on
could this be a thermostat problem
lennox hvac is offline   Reply With Quote
Old 04-08-2012, 09:44 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
fan is set to auto on the stat?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 04-08-2012, 10:06 AM   #3
Rewards Points: 614
Yes it sure could be a thermostat problem....... the bad news is it could be lots of other things ton .... take R of thermostat and see what happens
carmon is offline   Reply With Quote
Old 04-08-2012, 04:17 PM   #4
REP
How old is the thermostat and how long have you had the problem.
Could be a lot of things but my first guess would be a fan relay stuck closed.
If its a relay on a fan center then you can replace it,if its a relay that is part of the circut board then you will need to replace the board.
REP is offline   Reply With Quote
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
Carrier 58MVP -blower continues to run realprop HVAC 15 01-25-2012 12:37 AM
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 09:06 AM
Strange oil furnace problem: blower comes on before burner robparrott HVAC 6 12-12-2011 02:55 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
