Blower Fan Comes On/off Every Couple Minutes - HVAC - DIY Chatroom Home Improvement Forum
Old 01-18-2010, 09:45 PM   #1
Question
Blower Fan comes on/off every couple minutes
Recently my the blower unit in my house has started kicking on every couple of minutes. It stays on for a few seconds (literally less than a minute) and then stops. A couple minutes later it comes back on.
I have a heat pump, however this is just the blower fan in the house that is coming on, not the cooling or heating functions on the heat pump.
I thought this had to be the thermostat so I replaced it today and the new one is doing the exact same thing. (Tried both a Honeywell and a Hunter).
Does anybody have any idea what could be causing this?
Thanks!
jpoehls is offline   Reply With Quote
Old 01-18-2010, 11:11 PM   #2
Could be your furnace limit circuit is f-ed.
hvac benny is offline   Reply With Quote
Old 01-22-2010, 10:45 PM   #3
Fixed!
Ended up replacing the blower's circuit board and that fixed the problem.
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 01:21 AM
Inside Blower motor keeps running crawlerchris HVAC 1 12-19-2009 08:01 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
Additional Blower Control Lawrence Coppar HVAC 6 06-12-2009 05:53 AM
short on/off cycle times for burner/inducer diggerdave HVAC 31 02-27-2009 08:34 PM
