Blower Fan Bad - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-08-2009, 09:12 PM   #31
Hvac Pro
yuri's Avatar
Rewards Points: 2,260
From what I know heat pumps can be less comfortable for some people as the supply air temp is a lot lower than that of oil. Same thing with geothermal. They run longer with a lower supply air temp and older sedentary people or those with poor metabolism don't like that. That is why radiant heat is so popular. You may want to consider that as you will have to live with your decision for a long time. Cost is one thing, comfort another.
Good Luck
Old 06-09-2009, 11:20 AM   #32
a weed pops up
Originally Posted by brohar View Post
My Electric rates are currently around .08-.09.
i was using about 600 gallons of oil a year.
600 gals x 0.8 = 680 therms = 19,600 kwh = ~$2000, and you'd pay 1/3 of this with heat pump heat, depending on how often your outside temp. drops below 35F.
Old 06-09-2009, 03:03 PM   #33
In Cincinnati the mean number of days 32 degrees and under is about 100/per year. So how does that work into your calculation if i have to use electric to back up the heat pump.
brohar is offline   Reply With Quote
Old 06-09-2009, 04:28 PM   #34
1/3 of the year you'll be at the higher rate. 0.7 x 19,600 x .03= $400 +
0.3 x 19,600 x .09 = $530 = $930, total.
While I have your attention can I get the sq. footage of your house, including basement, for a top secret project I'm working on?
Old 06-09-2009, 08:59 PM   #35
The living area is about 1250 SQ which i do not think includes the basement. the basement is not heated or cooled but the basement ceiling is well insulated.
Old 06-10-2009, 12:14 PM   #36
Fwiw
SW Ontario, Canada
398.7 cubic meters = 140 therms of NG in 28 days = 5 therms/day
2900 sq. ft. including basement gives 5/2900 = 170 BTU/day/sq. ft.
664 HDD/28 = 24 HDD in one day
170/24 = 7.1 BTU/sq. ft./HDD
Effic. factor 0.8
final 5.7
D.C.
838 therms of NG in 90 days = 9.3 therms/day
3100 sq. ft. including basement gives 9.3/3100 = 300 BTU/sq.ft.
2658 HDD/90 = 30 HDD in one day
300/30 = 10 BTU/day/sq.ft./HDD
Effic. factor 0.8
final 8.0
SF, CA
2.3 therm/day
2700 sq. ft. gives 85 BTU/day/sq.ft.
540/30 = 18 HDD in one day
85/18 = 4.7 BTU/sq. ft./HDD
Effic. factor 0.8
final 3.8
San Diego, CA
29,000 BTU/hr = 21 therms/30 days = 0.7 therm/day
1560 sq ft including basement gives 0.7/1560 = 45 BTU/day/sq.ft.
270 HDD/30 = 9 HDD in one day
45/9 = 5.0 BTU/sq.ft./HDD
Effic. factor 0.8
final 4.0
victoria, BC
So 750 gals of oil giving 1100 therms for 4900 HDD for 180 days for 2000 sq. ft.
6.1 therms/day
2000 sq. ft gives 6.1/2000 = 305 BTU/day/sq.ft.
4900/180 = 27 HDD in one day
305/27 = 11 BTU/sq. ft./HDD
Effic. factor 0.8
final 8.8
Cincinnati, OH
600 gals/yr, 680 therms for 5096 HDD for 365 days for 1250 sq. ft.
1.86 therms/day
1250 sq. ft. gives 149 BTU/day/sq. ft.
5096/365 = 14.0 HDD in one day
149/14.0 = 10.6 BTU/sq. ft./HDD
Effic. factor already in there
final 11
Wisconsin Energy Study gives
4.4
1.7
Ranked
1.7
3.8
4.0
4.4
5.7
8.0
8.8
11
Range 1.7 to 11
Median 5.0
Average 5.9
Old 06-10-2009, 01:01 PM   #37
Yoyizit Thanks for including me, house size and location are dead on ....now what do I do with the 5.7
Chemist1961 is offline   Reply With Quote
Old 06-10-2009, 02:02 PM   #38
An old Tradesmen
Rewards Points: 7,356
Are those day light basements, or completely submerged/below grade.
Are they finnished basements?
Old 06-10-2009, 02:37 PM   #39
Since you're at 11 [my 40 yr. old house is at 8.0] I guess I'd look for some confirmation of your heat loss, and then look into payback periods for addt'l insulation, considering this along with how long you plan to live in that house. >10 yr. paybacks are almost the same as "never" and people move on average each 7 yrs.
In temperate regions insulating value may not be that important, but you're not in one.
http://www.energystar.gov/index.cfm?...sulation_table
But first get a lot of opinions from hands-on-HVACers.
Old 06-10-2009, 04:50 PM   #40
TOO MANY NUMBERS!!!!!!!
hvaclover is offline   Reply With Quote
Old 06-10-2009, 04:56 PM   #41
How 'bout I offer you $1 or $10 or $100? You want to go with the smaller number?
Old 06-10-2009, 05:00 PM   #42
Them kind of numbers talk!! They say "Clover it's time to go to the casino and drink La Batts til you puke"!
Old 06-11-2009, 08:32 AM   #43
im confused? so 11 is good? Anyways, Ive had 3 guys come out. One was a thief the other two are legit. Whats your thoughts on the York LX YHJF vs Carrier Performance Series 25HPA5?
Old 06-11-2009, 08:31 PM   #44
No, 11 is the most heat loss of all the samples I have.
Comfortmaker blower intermittent problem jh44ny HVAC 12 07-31-2011 06:41 PM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 06:57 AM
Acceptable Blower Vibration John_NH HVAC 15 11-21-2010 12:49 PM
Blower keeps cycling on and off simonb HVAC 1 01-17-2009 10:56 AM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 09:08 PM
