Blower control board
I just replaced the blower control board on my carrier 58GP100 with the ICM 271. Well it fixed the problem of the blower on all the time, however now the blower is out of sync with the burners. The burners will ignite and heat up the furnace and then shut off, then the blower will come on for a few minutes and blow hot air for a few minutes. And this cycle continues.. Before I replaced the board this was not the case. The blower was on the same time as the burners. It was just that the blower would never shut off. I took extra effort to connect the wires exactly as they were on the old board which had the old mechanical relays on it. Is there something else that needs to be changed? Is the new board possibly bad? Any ideas? Thanks
