Blower On After Startup Code 12 - HVAC - DIY Chatroom Home Improvement Forum
Old 11-16-2010, 12:15 PM   #1
blower on after startup Code 12
Hi, I have a Carrier furnace and every once in a while you hear the fan start as it usually does as it is preparing to light and then the fan suddenly quits and it flashes a code 12. This is a "blower on after startup" message. I have read a bit about this situation before on this forum but really don't understand what to do about it. Is this something to worry about? What causes it? What course of action should I take? Thanks for any help.
shopdude is offline   Reply With Quote
The Following User Says Thank You to shopdude For This Useful Post:
kwiseman (11-17-2010)
Old 11-16-2010, 06:40 PM   #2
An old Tradesmen
Rewards Points: 6,112
Means the thermostat was calling for heat. When the power was turned on to the furnace.
Check to see why its losing power(120 volt) while the thermostat is calling for heat.
Old 11-16-2010, 06:48 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,120
Probably the circuit board is dying. Broken solder joints.
Need advice; GC's ignorance of code to cost us extra? Merst Off Topic 9 06-12-2010 10:22 AM
Bryant Gas Furnace - blower sarts and stops montepix HVAC 7 12-24-2009 05:11 PM
Inside Blower motor keeps running crawlerchris HVAC 1 12-19-2009 09:01 PM
Problem with RUUD CH/A blower imabballer HVAC 2 01-09-2009 03:55 PM
Brand new PAYNE PG9MAB won't start . Error code 12 tp618 HVAC 3 12-19-2008 10:21 PM
