On Bloody HOT Room. - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-18-2009, 11:56 PM   #16
An old Tradesmen
Rewards Points: 6,132
2000 watts is 6,826 BTUs.
Old 04-19-2009, 02:05 AM   #17
Rewards Points: 180
One of my customers had the same problem and it appears that the floor of the above garage room wasn’t insulated
If there is an attic above this room, it would be worth looking to see if you have enough insulation up there too.
gma2rjc is online now   Reply With Quote
Old 04-19-2009, 01:08 PM   #18
Tap in
If you have Central Air and a place to tap into the main duct trunk line I would say tap into it and install a floor register near the exterior wall or tap in above if you have ductwork in the attic and install a ceiling register.
Big box stores have all the stuff you need to do the job.
Make sure everything is tight and well insulated.
SULTINI is offline   Reply With Quote
Old 04-19-2009, 02:52 PM   #19
An old Tradesmen
That will temper the room, but not cool it.
The computers and printer add too much sensible load.
At a 24 difference between retunr and supply air temp, it would take 263CFM to remove the sensible load of the equipment alone.
At 18 difference, it would take 350CFM, and at 16 delta it would take 395CFM.
Once the rest of the house was satisfied, and the thermostat shut off th system, the equipment will cause that room would heat up quickly.
Old 04-19-2009, 05:52 PM   #20
xxxxxxx
Old 04-19-2009, 05:55 PM   #21
I had the same thing for a NW 2nd story room. First, just try a fan.
"The method for calculating wind chill has been controversial because experts[who?] disagree on whether it should be based on whole body cooling either while naked or while wearing appropriate clothing, or if it should be based instead on local cooling of the most exposed skin, such as the face."
Old 04-20-2009, 08:14 AM   #22
Post
Good job
Originally Posted by gena View Post
Well, I agree. I know that its sound funny, but its just a term. Its just like a toilet paper.
Nice comeback, I notice Been is a real wise guy with knowledge.
We all know how smart he is he don't have to be that way.
Old 04-20-2009, 08:21 AM   #23
rahlquist
Some people answering questions on this forum think everybody knows all the HVAC lingo, they don't it's a DIY site.
Go back to #18 try that with room darking shades if you have central air.
Old 04-20-2009, 08:56 AM   #24
An old Tradesmen
LOL...
Your probably the only one that took offence from that.
The OP, can probably get a Chiga Mini split installed for a very low price.
Old 04-20-2009, 11:12 AM   #25
warm air return
Originally Posted by beenthere View Post
In cooling mode. Its a warm air return.
Why would you want to remove cold air from a hot room.
Funny after 40 years in HVAC never heard anyone ever call it a warm air return, even that's what it does in season.
COLD AIR RETURN, GOT IT .
Hello MR. counterman I need a warm air return grill, you need what?? A warm air return grill.
What's your account under,? I don't have an account you don't have a warm air return grill either. Call a HVAC mechanic.
Old 04-20-2009, 11:35 AM   #26
An old Tradesmen
LOL...
Yes, some people get stuck in their little corner of the world.
And forget there are places that don't need heat.
Just cooling.
In those places, they are not called cold air returns.
Believe it or not. Philly isn't the center of the world.
Old 04-20-2009, 12:19 PM   #27
An old Tradesmen
If you don't have an account, that would be your problem.
Old 04-20-2009, 12:50 PM   #28
sweaty
Rewards Points: 276
Seal and insulate over and under that whole level. Also, put in a radiant heat barrier wherever the sun shines on.
sweaty is offline   Reply With Quote
Old 04-20-2009, 06:45 PM   #29
Philly
LOL...
Just cooling.
Nobody said PHILLY is the Center of the world. If you only knew the places I have been, get it have been.
I have lived in Florida two times I recall the A/C lingo as just return air not hot or cold.
Face it Been you been had.
You wish you could get a good Hoagie or Chessesteak.
Hey Florida mechanics what's the word on return air.
Old 04-20-2009, 06:47 PM   #30
Account
That's not me asking the question that's you asking for a warm air return grill.
I wouldn't ask for a warm air return grill.
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 08:28 PM
A room in a room? artosie General DIY Discussions 2 03-10-2009 01:43 PM
Cold Room mikelbeck HVAC 14 01-16-2009 09:21 PM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 03:51 PM
