On Bloody HOT Room. - HVAC - DIY Chatroom Home Improvement Forum
Old 04-17-2009, 02:03 PM   #1
Question
On bloody HOT room.
Ok I have nobody to blame but myself for this but here is the situation. We have a split level 3BR home. 1 BR is dedicated as our hobby/tech room. In this room we have 3 Desktop PC's. In addition this room is on the southwest corner of the house so gets more afternoon sun and any other room in the house. It is not uncommon for this room to hit 85 deg while the rest of the house is in the low seventies. I do have good access to the floor of the room as its over the garage. Does anyone have a good suggestion for how to deal with this miserable room? My wife works from home and this room is where she is stuck 6-8 hours a day.
Thanks!
rahlquist is offline   Reply With Quote
Old 04-17-2009, 03:29 PM   #2
HVAC / Plumbing
mini split, window unit, portable
kenmac is offline   Reply With Quote
Old 04-17-2009, 05:03 PM   #3
An old Tradesmen
Rewards Points: 8,154
Window unit.
The least expensive upfront method.
Old 04-17-2009, 06:10 PM   #4
One of my customers had the same problem and it appears that the floor of the above garage room wasn’t insulated.
gena is offline   Reply With Quote
Old 04-17-2009, 06:27 PM   #5
Cant do the window unit due to noise, thats also the reason we dont use something like a box fan etc. I've hlaf considered trying to put in a return in the room but am unsure if that would help.
Old 04-17-2009, 06:41 PM   #6
Here we go; you should be started from that! Of course, you need a cold air return!
Old 04-17-2009, 08:26 PM   #7
An old Tradesmen
In cooling mode. Its a warm air return.
Why would you want to remove cold air from a hot room.
Old 04-17-2009, 08:48 PM   #8
Well, I agree. I know that it’s sound funny, but it’s just a term. It’s just like a toilet paper.
Old 04-17-2009, 09:29 PM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 382
With 3 computers giving off heat etc gonna need a minisplit. Quite a few BTU's to remove and one normal A/C vent won't provide enough cooling to do that.http://www.fujitsugeneral.com/wallmounted9-12RL.htm
Old 04-18-2009, 04:13 PM   #10
Crazy, but lovable
flyboy2610's Avatar
It's not just the air you want to remove from the room, but the humidity.
A room with high humidity is going to feel much warmer than one with low humidity.
Why is noise such an issue in this room?
flyboy2610 is offline   Reply With Quote
Old 04-18-2009, 05:01 PM   #11
Humidity in this room is lower than most rooms in the house due to the elevated temp and there is a cat litter box too (its 82.9 right now). Noise is an issue because my wife is a work at home CSR and she doesnt need a bunch of loud noise in the room. Something as loud as a box fan would be excessive even on low. the room is approx 10x14.
Old 04-18-2009, 05:33 PM   #12
HVAC / Plumbing
If a box fan is too loud A mini split be also . They are quite. But not completely.. They do have a fan
Old 04-18-2009, 05:36 PM   #13
Hvac Pro
yuri's Avatar
Rewards Points: 382
Mini split units are VERY quiet. Fujitsu has a heat load calculator to size them. You need to know approx how many BTU/hr your computers produce, including the monitors. You only have 3 options: window shaker, portable or minisplit. Also, heat rises so that is why the problem is worse upstairs. A minisplit does need somewhere to drain the indoor unit and they are complicated to install. Find a reputable contractor who has installed lots of them before going with them or build an office in the basement if it is cooler there.
Old 04-18-2009, 07:01 PM   #14
This is starting to sound like the best idea. Are you aware of any calculators I could use to estimate the heat generated by the computers based on their watage? I can take a wild guess at the max wattage of all 3 computers and the one printer as roughly 1500-2000 watts max.
Old 04-18-2009, 07:29 PM   #15
Hvac Pro
yuri's Avatar
Rewards Points: 382
I have access to Fujitsu's calculator but not the heat output of the computers. Hang in there and maybe someone else will help. If you have old CRT monitors those give off lots of heat. The flat panel don't. Try contact Dell or HP and maybe they have that info.
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 07:28 PM
A room in a room? artosie General DIY Discussions 2 03-10-2009 12:43 PM
Cold Room mikelbeck HVAC 14 01-16-2009 08:21 PM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 02:51 PM
