Blocked Oil Furnace Exhaust - HVAC - DIY Chatroom Home Improvement Forum
Old 11-27-2012, 05:17 PM   #1
blocked oil furnace exhaust
my oil fired furnace is buring rich and keeps shutting down i think due to a blocked exhaust. I cant unclog it because i can't see the exhaust pipe inside the chamber. The stack and inside of the furnace where i can access it is clean as is the chiminey.
MikeNH is offline   Reply With Quote
Old 11-27-2012, 05:23 PM   #2
Rewards Points: 1,216
When was the last time the top was taken off and brushed through to the chamber and vacuumed?
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 11-28-2012, 04:28 AM   #3
An old Tradesmen
Rewards Points: 7,808
Could be other issues, such as a fouled nozzle, or dirty cad cell.
Old 11-28-2012, 08:49 AM   #4
Rewards Points: 610
oil burner fan blades may also be clogged..this would result in too little air for combustion...also air intake on oil burner may require adjustment..usually one screw on rotating damper on end of burner..loosen and increase air position a little at a time...OR oil pump pressure may be too low or too high..suggest getting heating tech to check out and set up..too many variables to consider by guessing...smoke test or better still , flue gas analyzer should be used to be sure.
techpappy is offline   Reply With Quote
Side vented furnace blocked by snow lindsayspop HVAC 5 01-03-2010 02:38 PM
Insulate or sleeve furnace exhaust Chemist1961 HVAC 7 01-28-2009 06:58 PM
exhaust smell when the furnace kicks on puchead77 HVAC 5 01-19-2009 01:11 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
