Old 04-13-2010, 06:52 PM   #1
blockage in heating system
I live in a 3 story house that is heated with hot water. We are getting heat in only the back half of the house. Heat will not flow to front half. We have replaced pump, thermostat, and installed a bleeder on the feed line to the front of the house. Have bled the system several times with no success in getting heat to return. Could this be a mechanical issue in the radiator valves? If airbound, bleeding does not seem to work.
jayvee is offline   Reply With Quote
Old 04-13-2010, 08:56 PM   #2
Remodeling Contractor
it is air bound. you may need to increase the pressure to force it out. Also you may need to add bleeder valves at the heat units.
Old 04-13-2010, 09:31 PM   #3
Xtreme DIY'r
So when you bleed you are getting water out of the bleeders ?
Old 04-13-2010, 09:56 PM   #4
Yes, water did come out of radiators when bled. Also, we did install a bleeder valve and still no heat. Have you heard of a "swirl bleeder?"
Old 04-13-2010, 10:06 PM   #5
Xtreme DIY'r
When it calls for heat is the recirc pump running ?
Old 04-13-2010, 10:10 PM   #6
yes, the circulating pump is running when it calls for heat
Old 04-13-2010, 10:12 PM   #7
Is it possible that there is a mechanical blockage in one of the radiator stem valves? If so, how can I determine which radiator is blocked?
Old 04-14-2010, 07:01 AM   #8
An old Tradesmen
Do you have 1, or 2 circulators? Is it a zoned system, that you have 2 thermostats?
If you have 2 zones/circulators. Is it possible that you have the circulator installed pumping in the wrong direction?
old heating system jtb003 Plumbing 2 01-30-2010 09:48 PM
Switching from old Oil Heating system, advice needed captainobvious HVAC 2 09-29-2009 02:18 PM
no ciculation in one zone of forced water heating system srossdiy Plumbing 2 01-27-2009 11:39 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
Solar Wall Heating System Educator HVAC 5 03-14-2008 02:24 PM
