Bleeding Radiators And Adding Water - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-25-2013, 09:07 PM   #31
An old Tradesmen
Rewards Points: 7,816
Originally Posted by plummen View Post
Most of the time they hadnt been serviced in years and no rust inhibitor in water.
Once I got the steam boiler in my big building under control by completely fushing the system several times and getting the chemicals/rust inhibitor in the system my utilitie bills for heating went from $2000.00 plus on really bad months down to closer to $1200.00 on really bad months to heat with that old 93hp kewanee.
I would flush some trash out of system in the morning and some at night,then on saturday mornings Id flush maybe 50 gallons out of bottem of boiler.
All the late night calls I was getting about no heat stopped after I started checking the system daily,the serious cuts in the gas bill made it worth the little extra time everyday to stop by and check things out.
But why are you comparing a steam boiler to a water boiler. They aren't the same, steam is not a closed system.
Old 01-25-2013, 09:16 PM   #32
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
I work on both kinds,my steam boiler is closed/returns back to boiler
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-25-2013, 11:22 PM   #33
An old Tradesmen
Your steam system has air vents. Unless its a vacuum system.
Old 01-27-2013, 09:50 AM   #34
Rewards Points: 12
One additional question about bleeding radiators
Seems like my plan to bleed is okay. Now I'm wondering, is that what I should try first? Here is the deal, the boiler was installed around 2007 or 2008 in my 2 story 100 year old house. It replaced a converted coal boiler. I noticed a week ago that it was getting warm upstairs but not so much on the main floor. The main floor radiators do warm some but not much.
I posted questions about bleeding and have gotten some useful info and have developed a plan but everything is based on me asking about bleeding. What if I am wrong to start with this? Please, some of you that have followed this - would you start with bleeding?
hubbard is offline   Reply With Quote
Old 01-27-2013, 11:17 AM   #35
An old Tradesmen
No harm will be done by attempting to bleed it first.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
hubbard (01-27-2013), oh'mike (01-27-2013)
Old 01-27-2013, 11:34 AM   #36
DIY staff
Rewards Points: 7,174
You have some very experienced boiler guys waiting to help if bleeding is not the cure----
And at least one homeowner (me) that has just enough knowledge to confuse you!
Old 01-27-2013, 02:04 PM   #37
how
Rewards Points: 1,104
Rad bleeding is just a regular part of yearly boiler maintenance. Just follow your plan in post 19.
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
Old 01-28-2013, 09:16 AM   #38
Hmm
I would go to Home Depot buy a pressure reducing valve, plumb that into the system. You have plenty of isolation valves so it would not be hard. Burnham does say pressure reducing valve or isolation valve, but its so much easier to have one. It would go right after the backflow preventer you have in there. By the way I think most backflow preventers like to be oriented horizontally so you can correct that while at it as well. Then I would bleed the baseboards and should be ok. If you are adventurous you migh want to look into re-arranging the pump to be on the supply and pump away from the expansion tank. The current theory of hydronics makes that the preferred location for the circ.
russiand is offline   Reply With Quote
The Following User Says Thank You to russiand For This Useful Post:
hubbard (01-28-2013)
Adding heat to a basement, newbie questions frizbplaya HVAC 3 01-28-2011 02:57 PM
adding new radiators to a slab home renofixit99 HVAC 2 01-02-2011 06:13 AM
Steam Radiators Problem ouch202 HVAC 3 11-27-2010 09:26 AM
Coverting from Steam to Hot water Boiler ericm215 HVAC 1 05-23-2010 10:03 PM
Water Heater leak help needed :/ bluecifer Plumbing 9 12-17-2008 11:05 AM
