Bleeding Radiator - HVAC - DIY Chatroom Home Improvement Forum
Old 11-30-2009, 07:51 PM   #1
bleeding radiator
I have a gas boiler. I'd like to bleed my radiators but the instructions say to turn off the main heat system. I'm concerned that if I turn it off the pilot light will go out.
Thank you
Suzanna is offline   Reply With Quote
Old 11-30-2009, 08:10 PM   #2
Hot water or steam ?
I have hot water & I have bled mine with the heat turned down so it won't circulate water while I'm bleeding them
Old 12-01-2009, 03:44 AM   #3
I have hot water as well.
Thank you for your reply, turning down the heat instead of turning the whole thing off.
Old 12-04-2009, 05:01 AM   #4
An old Tradesmen
Rewards Points: 7,816
For future reference, turning off the electric to a boiler won't shut off the pilot.
Old 12-17-2009, 06:26 AM   #5
Another question
I have another question about radiator bleeding. I have an old row house that is divided into five apartments. If I bleed the radiators, do I have to do the whole house (all the radiators) or can I just do one apartment. It's just one apartment where the radiators seem to be not cranking out heat.
Old 12-17-2009, 10:42 AM   #6
An old Tradesmen
Best to do them all.
That way you catch the others before they become a problem.
Is your expansion tank a bladder tank, or steel compression tank.
If compression. you may want to drain it. Good chance its water logged.
Removing a Cast Iron Radiator MugsynSax Plumbing 1 10-05-2009 04:18 PM
No/little heat on 3rd floor apt collar Plumbing 3 12-06-2008 07:17 AM
radiator system unequally warm despite bleeding amakarevic Plumbing 11 11-20-2008 09:06 AM
Hot Water System -- Cold Radiator formarley HVAC 4 03-04-2008 07:09 AM
Bleeding Steam Radiator during heating season helplessowner HVAC 1 01-24-2007 12:15 PM
