Bleeding My Heating System 1-2-3 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-31-2006, 03:48 PM   #1
Send a message via AIM to bwoo Send a message via Yahoo to bwoo Send a message via Skype™ to bwoo
Bleeding my heating system 1-2-3
Hi,
Just wondering is there a "preferred" or "right" way of bleeding my hydronic heating system?
I see valves on the supply end, and I could also bleed from my return side (but if I do that I bleed the whole system).
Also, is the proper way to shut off the supply and/or the return?
Thanks in advance!
ben
bwoo is offline   Reply With Quote
Old 12-31-2006, 04:02 PM   #2
I can help with your problem but have a couple of questions first.What presure is your boiler at curently and does it have a presure reducing valve on the water supply line,or due you have to fill it manualy.
trollmastergeneral is offline   Reply With Quote
Old 01-01-2007, 10:16 AM   #3
The pressure is at 25psi. And yes, it does have a pressure reducing valve
Old 01-01-2007, 11:17 AM   #4
Are your boiler drains on the supply or return lines. Isthere shut offs on supplys and returns. A picture sure would help. Your presure should be around 15 psi .Is your expansion tank full of water?
Old 01-01-2007, 11:59 AM   #5
i'll post a picture in the next post. however, I actually removed all my expansion tanks in the hope of reducing my electric bill. i had another post in which i was asking about glowcore. do you think the removal of my expansion tanks make a difference?
Old 01-01-2007, 12:09 PM   #6
Yes that is most likely why you are running at 25 psi. Check your presure reducing valve it will say 15 psi. Your t&p valve will open up at 30 psi. When you heat up the water it expands this is why you need the expansion tank. Did you replace your glowcore aka glowlesscore
Old 01-01-2007, 12:15 PM   #7
Thoroughbred Mopar Man
Rewards Points: 502
Hi bwoo
If you go to page #9 and find the post Bleeding air-Hot water system by Dragon I laid out some pretty specific details in this one. If you need any help past that let us know. If you can get a guy by the name of mdshunk involved he is very intelligent. I have not seen him on here for a while though. Let us know and we will help you through this.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 01-01-2007, 01:43 PM   #8
no i didn't replace them. instead, i took them out of action. i'm posting two diagrams..
This first one i call 2006
And this second one i call 2007
All I did was take the glowcores out of action. Based on this, do you still recommend that I drop the PSI to 15?
My major issue is this.. on the 4th floor (Zone 4), i can get the supply to be really really hot, but on the return side (at the air handler), it is only luke warm.
Do you recommend that I put the glowcores back into action?
Old 01-01-2007, 01:45 PM   #9
#CARRIERMAN,
Thanks for the tip. It's a long post so I've printed it out to read. vbmenu_register("postmenu_28390", true);
Old 01-01-2007, 01:45 PM   #10
trollmastergeneral and #CARRIERMAN,
do you guys work as professional HVAC engineers? if so, which geographies do you cover?
b
Old 01-01-2007, 01:59 PM   #11
just realized something - trollmastergeneral, when you mean expansion tank, you're referring to my glowcores right?
Old 01-01-2007, 02:22 PM   #12
as for my boiler, it's a Laars Endurance model EBP which is described by Laars as:
This appliance is a low pressure, direct
vent, hot water boiler that provides priority domestic
hot water on demand as well as hydronic space
heating. The unit has a twenty gallon tank which holds
boiler water (as opposed to domestic water storage).
The boiler water is kept hot at all times to
provide immediate response to call for heat or
domestic water. Domestic water is heated by the boiler
water through a stainless steel plate heat exchanger.
So, do I still need the glowcores?
Old 01-01-2007, 02:27 PM   #13
b
I am not a engineer but I am a licensed contractor in michigan.I specialize in service because I love service.I love boilers and steam heat because it is a specialty item not many people know how to repair these systems. I have been in HVACR since 1987.I have owned my own buisness for the last 11 years ago. I am not against home owners who need help either.
Old 01-01-2007, 02:33 PM   #14
I see that zone 4 has a pump is this the zone is not working. Which zone is not working. Is this the only zone not working?
Old 01-01-2007, 02:44 PM   #15
This is getting a little confusing. What is the original complaint that made you want to bleed the system.
Bleeding a boiler system jpg HVAC 1 12-16-2008 04:53 PM
Bleeding Steam Radiator during heating season helplessowner HVAC 1 01-24-2007 01:15 PM
Hot Water Heating System Estimate Cost ? helpless handyman HVAC 45 12-26-2006 10:59 AM
Need some serious advise on heating system helpless handyman HVAC 26 12-07-2006 06:28 PM
