Bleeding The Air Out Of A Boiler System - HVAC - DIY Chatroom Home Improvement Forum
Old 10-10-2011, 10:50 PM   #1
Rewards Points: 12
Bleeding the air out of a boiler system
I just completed repairs on a three zone baseboard heat boiler system (replace zone valves and expansion tank). I am now having issues bleeding the air out of the system. On the return side (from top to bottom) are three drain valves, three shut off valves and three zone valves. Pictures below. Can anyone walk me through the correct process. Thanks
slamseven is offline   Reply With Quote
Old 10-11-2011, 08:47 AM   #2
biggles's Avatar
one zone at a time....connect a long drain hose to one petcock and let it cycle the water make up right thru the boiler up thru the zone being drained and the air will flush out noting ON no circ pumps, no boiler, shut the isolating valves as you do each zone..then the EX tank will catch the rest
Old 10-11-2011, 04:03 PM   #3
REP
Get and install a Spirotherm air vent.Installed properly and you will never have to worry about air in the system again.It worrks.
Nothing else is even close.
REP is offline   Reply With Quote
Setting the reset "Curve" for a modulating boiler (modcon) mknmike HVAC 5 02-10-2011 12:37 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
bleeding a boiler system big fred Plumbing 4 12-12-2009 09:08 AM
Which heatings system should I go with? keano016 HVAC 5 12-01-2009 03:53 PM
Bleeding the Air out of boiler without bleeder valves beetlebabs Plumbing 9 12-12-2007 01:37 PM
