Bleeder Valve Vs Water Valve: Choices??? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-14-2007, 06:42 AM   #1
Bleeder Valve vs Water Valve: Choices???
I have HW Baseboard heat and need to put bleeders in. I have seen those small water valves that go on water lines for ice-makers, humidifiers, etc. that clamp on and penetrate the copper line.
What is your opinion on using those as bleeder valves as opossed to opening the system and sweating a regular bleeder valve in at an elbow?
THanks
Roztom1 is offline   Reply With Quote
Old 10-14-2007, 03:31 PM   #2
scotch on the rocks
hvactech's Avatar
sooner or later they'll leak, there are some you can braze without draining the loop, Johnstone suppy sells them.
hvactech is offline   Reply With Quote
Old 10-14-2007, 07:30 PM   #3
THanks
The water valves for ice makers are not designed to for the hot temps of a boiler. The rubber gasket will eventually leak and destroy your floor.
Do you have a friend that is a plumber?
redline is offline   Reply With Quote
Replace toilet water shutoff valve abastin Plumbing 14 02-14-2011 03:41 PM
Master (water) shutoff valve rmdyjoe Plumbing 7 12-05-2008 08:55 AM
Replacing water heater drainage valve darsunt Plumbing 2 10-08-2007 09:17 PM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 02:17 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
