Bleeder Valve vs Water Valve: Choices???
I have HW Baseboard heat and need to put bleeders in. I have seen those small water valves that go on water lines for ice-makers, humidifiers, etc. that clamp on and penetrate the copper line.
What is your opinion on using those as bleeder valves as opossed to opening the system and sweating a regular bleeder valve in at an elbow? THanks |
sooner or later they'll leak, there are some you can braze without draining the loop, Johnstone suppy sells them.
Do you have a friend that is a plumber? |
| All times are GMT -4. The time now is 06:46 AM. |
