Bleed Screw Question. - HVAC - DIY Chatroom Home Improvement Forum
Old 01-12-2009, 04:38 PM   #1
Bleed screw question.
Hell, My furnice wont stay primed. Will go for days then it has all sorts of air in the line that needs to be bled out. While bleeding I notice there is a good drip from the thread area of the bleeder screw. Could this be the reason for loss of prime of is the culprit somwhere else? I have been told that it should not leak out of the threads while im priming it but wasnt sure. I tried getting a new bleeder screw but the hardware store told me that I had to buy a new pump for it. Could this actually be why I get air?
Single Line system
Inline Canister filter installed and new this season
New nozzle at start of season too.
Thanks for any help you can be!
Justin
justin_92_92 is offline   Reply With Quote
Old 01-12-2009, 05:23 PM   #2
What is a "furnice"?
hvaclover is offline   Reply With Quote
Old 01-12-2009, 05:37 PM   #3
An old Tradesmen
Rewards Points: 7,816
The bleeder screw is not the problem.
Old 01-12-2009, 06:06 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 174
Furnice = Nice furnas.
Old 01-12-2009, 07:08 PM   #5
Thanks for taking the time to help a DIY'er
If it help you HVAC Please read furnace where it says furnice.
Old 01-12-2009, 07:13 PM   #6
Well since you have a hot water system that is heated by a BOILER,
you threw me with the term "Fernice".
Old 01-12-2009, 09:55 PM   #7
I dont have a boiler. I have a trailer furnace in a double wide home.
Old 01-12-2009, 09:59 PM   #8
OH! So you got an oil "fernice". I get it now
Old 01-12-2009, 10:04 PM   #9
yuppers! Its a pain in my neck "furnice" rite now.
Old 01-13-2009, 05:31 AM   #10
An old Tradesmen
Did you find your air leak yet?
Old 01-13-2009, 11:35 AM   #11
Well, Not yet.
Im about to go out and take absolutley every conection there is apart and check to make sure the flare is PERFECT and re-tighten back up. See I have a piece of soft copper go from the tank to a hard copper piece that I soldered together- Back to another longer soft copper piece that goes to the OIL FURNACE.
Could I really have done a crappy solder job...doubtfull but possible. I think the issue may be in the transition from the hard copper to the soft (Under the house ) Wish me Luck
Old 01-13-2009, 11:42 AM   #12
Back in the day we would use a vacuum pump to isolate the supply line. If the vacuum held we know the supply line was good.
Hope this helps you get your oil "fernice" back on line
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 01:54 AM
Sheared head on Tapcon screw - how to remove? mkuether Remodeling 9 12-04-2008 08:18 PM
Question about removing a screw type fuse box... OmegaBunny Electrical 9 09-15-2008 10:13 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
New service Question Onytay Electrical 1 10-24-2007 05:47 AM
