Bled Air Out Of Radiator System Expansion Tank - HVAC - DIY Chatroom Home Improvement Forum
Old 11-18-2008, 10:01 PM   #1
Rewards Points: 1,062
bled air out of radiator system expansion tank
while guessing a fix for another problem:
radiator system unequally warm despite bleeding
should i pump it back in and how much ?
Old 11-18-2008, 10:23 PM   #2
Rewards Points: 2,906
Typically, they operate hot water heating systems at about 12 psi. If you go much lower than that you run the risk of having cavitation occur in your circulating pump. You need some pressure to prevent vapour bubbles from forming on the circ pump impeller.
So, use an air pump to pump your expansion tank up to 12 psi and you should be OK.
Nestor_Kelebay is offline   Reply With Quote
Old 11-19-2008, 04:29 AM   #3
An old Tradesmen
Rewards Points: 6,470
Are you sure he has a bladder tank.
how to install a expansion tank to a gas boiler iris Plumbing 2 10-08-2008 03:17 PM
Hot water heater expansion tank? rjniles Plumbing 3 06-21-2008 11:53 AM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
