Old 12-04-2008, 05:39 PM   #1
black inside airvents???
I live in south Florida and am helping my dad paint inside his house. When we took off the covers for the air vents we noticed that the fiberglass is black. Is the normal with age or is it a problem? If it is a problem what wouldwe need to do to fix it? Thanks
sflamedic is offline   Reply With Quote
Old 12-04-2008, 05:52 PM   #2
Hvac Pro
It may be dust and it may be mold if it is very humid where you are. I was in Orlando and it was very humid there. If you want to be sure take a piece of it to an environmental or air quality testing lab to find out what it really is. Mold is horrible and very bad for some people's health.
Old 12-04-2008, 06:49 PM   #3
hvaclover's Avatar
Test kits available at HD and Lowes.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 12-04-2008, 09:56 PM   #4
What can I find here?
Winchester's Avatar
Fiberglass in an air vent? Not sure about that one, but in the case of some of my cold air returns, the installer had painted the areas black. I guess this helps hide the install (ranging colors behind the grille) between the inner wall, studs, and sheetrock.
Winchester is offline   Reply With Quote
Old 12-05-2008, 08:27 AM   #5
Did it look discolored (not really black), or did it look like black fiberglass mat? If it is the latter, this is a more expensive boot/insulation designed to prevent mold/mildew growth. It is very common in Florida. Here is a picture of lined duct board:
They make boots with this fiberglass matting on it as well.
bluefitness is offline   Reply With Quote
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 04:05 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
refitting black pipe that has black gunky dope settled in amakarevic Plumbing 6 06-16-2008 01:05 PM
Install hardwood over black mastic? SuperDoug Flooring 2 10-28-2007 01:52 PM
Is there any black PVC ? Melanie337 Plumbing 2 09-15-2007 01:03 AM
