Bird In The Heat Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 04-22-2010, 11:54 PM   #1
Rewards Points: 324
Bird in the heat duct
My mom had a bird in her house, trapped in a heat duct a few days ago. It was going back and forth between a heat vent in the kitchen to a vent about 30' away in the family room. She heard scratching and thumping and didn't know what it was, but then she saw its claws and beak sticking up through the vent.
When she was sure it was over near the kitchen vent, she pulled up the vent in the family room and covered it with a laundry basket turned upside-down so the bird could come out but not fly around in the house.
She's not positive, but she thinks it came in through either the exhaust pipe or the fresh air intake for the furnace. They found a dead bird in the furnace last year.
Is there something she can do to prevent the birds from getting in through those pipes? That is, if it is how they're getting in. We thought about covering the openings outside with wire mesh or chicken wire, but we live in Michigan and we're afraid ice would build up on the wire in the winter and block the openings.
Any ideas or suggestions?
Thanks!
Barb
gma2rjc is offline   Reply With Quote
Old 04-23-2010, 12:01 AM   #2
Check your terminations at the chimney, fresh air and combustion air - there should be some sort of grill or mesh to prevent this from happening. If not, visit your local sheet metal house and get a proper fitting that will stop birds but not allow ice to build up. If she found the bird in the blower section, then it pretty much had to come from the fresh air intake; if it was in the burner section, then check your chimney. Hope this helps.
statman is offline   Reply With Quote
Old 04-23-2010, 12:48 AM   #3
Rewards Points: 324
Thanks Statman. She doesn't have a chimney, there are two white (pvc?) pipes that come out of the side of the house. Do they make something for those?
Barb
Old 04-23-2010, 06:47 AM   #4
An old Tradesmen
Rewards Points: 6,458
It didn't come in through the PVC pipes for combustion air and flue exhaust. They go to the burner box, and the inducer. There would be no way to get to the air ducts from there.
You may have a fresh air duct for the house.
If so, a screen can be put on it..
Old 04-23-2010, 05:19 PM   #5
Rewards Points: 324
Thanks beenthere. I'll have my mom ask the guy who installed the furnace about it. He would probably be the one who installed the fresh air duct.
Barb
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 04:59 AM
Aux heat doesn't come on during defrost cycle hesse HVAC 5 03-18-2010 05:10 AM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 10:27 AM
DIY heat duct wayne1 General DIY Discussions 1 10-19-2009 07:01 AM
