Old 10-30-2009, 10:08 PM   #1
Question bigger vent needed?
tomorrow i'm hooking a hot water heater up to do some radiant floor heating for us. i want to run this out the same 3" vent out the roof as the domestic use hot water heater.
a contractor friend would be more comfortable upsizing it to 4".
is this necessary?
thx
DIYgeorge is offline   Reply With Quote
Old 10-30-2009, 10:54 PM   #2
old pro
You may need 5". Each water heater is about 35,000 to 40,000 BTU's. Chimneys are sized according to the amount of BTU's into them AND the vertical rise AND this needs to be determined by the gas code book and a gas fitter with knowledge of how to use and interpret it. Undersize the chimney and you will get fumes in the house or flamerollout and possible fire and insurance company problems.
Old 11-01-2009, 06:13 AM   #3
An old Tradesmen
Or just a dead family.
Old 11-01-2009, 10:36 AM   #4
old pro
Colorless, odorless and LETHAL that CO gas.
Old 11-01-2009, 11:22 AM   #5
Thumbs up went direct (power) vent
keeping the original vent for the 1st water heater.
put in a power vent.
thanks for all your input.
also found this jewel...
http://www.duravent.com/pdf/shbook.pdf
Old 11-01-2009, 11:29 AM   #6
old pro
VERY nice link. Thanks
More On This Topic
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
Now we're going to be doing chimneys. So we're going to do yellow and rose and a little bit of blue. And produce the dark part of the chimneys. Now we're going to lighten it up and do the light part of this chimney. And we have to go darker on this... Read More »
Being a chimney sweep is a dirty job, but it's certainly something you can make money doing. Starting a chimney sweep business takes a substantial initial investment, but if you do quality work you can recoup that money in no time. Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a duct test in this house. I want to tell you why in two different ways. Number one, if your unit is in the garage and the holes are on the... Read More »
Hi, I'm Bobby on behalf of Expert Village. Everyone loves having a warm fireplace on a cold winter day. The downside to that is that you have to clean the fireplace. In this series we are going to show you how to clean the inside of your fireplace, your... Read More »
Cathedral ceilings--ridge vent needed, or not? Larenda Roofing 5 06-04-2009 10:32 PM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-17-2008 01:11 AM
pre-stubbed basement bath vent needed? ameleus Plumbing 7 09-21-2008 12:26 PM
Source needed: 6" Vent Hood for siding STEPHENWANGEL Remodeling 8 09-02-2007 12:52 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
