Better To Turn Off Furnace At Night Or Not? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-17-2011, 10:43 PM   #1
Rewards Points: 79
Better To Turn off Furnace at Night or Not?
we have a 2300 sqft 80+ yr old house that has little insulation and single pane wooden windows. Last year we would set the temp on our t-stat over night to <40 deg to stop the furnace from turning on. Winter gas usage was over 175 therms a month last year so I am wondering if it's actually less efficient to let the indoor temp drop to 50 at night and then bring it back up to 63 in the morning, than to say keep the temp at 60 overnight.
our furnace is 90+ efficiant natural gas forced air 95,000 btu i believe. It's slow, raises the temp about 4 - 5 deg per hour.
linuxrunner is offline   Reply With Quote
Old 10-18-2011, 12:04 AM   #2
REP
What we were told way back when,is that you save one percent(of the gas that you would be usingt) for every degree that you set back over a 10 hour span.It is not a lot of gas per day,but it should be enough to see a differance at the end of a month.
REP is offline   Reply With Quote
Old 10-18-2011, 03:53 AM   #3
An old Tradesmen
Rewards Points: 9,660
Add insulation anywhere you can, and seal your house up better.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Furnace won't turn on....no power? doningarden HVAC 1 12-01-2009 03:43 PM
Ruud natural gas furnace occasionally will not turn on BillyT1 HVAC 3 01-30-2009 03:42 PM
