Best Way To Seal Sheet Metal To Wood - HVAC - DIY Chatroom Home Improvement Forum
Old 09-10-2009, 03:16 AM   #1
Rewards Points: 392
Best way to seal sheet metal to wood
I'm doing a cold air return with the 20x20 duct transitioning to floor joist sections and drywall. I want to run a bead of something between the sheet metal and the wood of the floor joists. Should I use duct mastic for this? Regular silicone? Polyurethane? Latex caulk? Some kind of adhesive? joint compound?
What is standard for sealing this interface? It's cold air return so I don't have to worry too much about temperature differences.. But I don't want cracks to open up over time..
-Jeff
zootjeff is offline   Reply With Quote
Old 09-10-2009, 07:06 AM   #2
-Jeff
Red RTV silicone
hvaclover is offline   Reply With Quote
Wood Fence with metal post BDestroyer8418 Building & Construction 8 09-24-2011 09:49 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
metal or wood soffit framing WTDoc Carpentry 1 03-31-2008 09:06 AM
Attaching Roof to side of home joe3534 Roofing/Siding 1 04-29-2007 09:54 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
