Best Way To Seal Between Furnace And Coil? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-09-2012, 04:16 PM   #1
Best way to seal between Furnace and Coil?
I just installed a Goodman Gas furnace (downflow) with the coil under the furnace. I'm wondering what is the best way to seal the seam between the furnace and coil as there is a decent amount of air leaking out. Ideally i assume there would be some sort of transition made up between the two but in this case space is at a premium (low ceilings)
should I use some sort of foam? silicone? metal tape? duct tape?
Thanks!
drnick5 is offline   Reply With Quote
Old 07-09-2012, 06:55 PM   #2
Silicone works well. Next time run the bead of silicone before setting the furnace on the coil.
Can a furnace sit on top of the evaporator coil? Yvonnef11 HVAC 9 03-15-2012 07:24 AM
New furnace and a/c coil install done raylo32 HVAC 4 10-05-2011 08:46 PM
Damaged fins on furnace EVAP coil rlukas79 HVAC 5 12-21-2010 04:10 PM
Evaporator coil measurement with gas furnace softsoc HVAC 3 08-11-2010 07:41 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
