Best Way To Run PVC From Forced Air Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 08-26-2008, 11:05 PM   #1
Smile
Best way to run PVC from forced air furnace
Hi all - 2nd post. Replacing Nat Gas forced air furnace. Old one vented through 5 in round galvanaved to chiminey (hole to chiminey in base ment). New one vents via PVC. Need input on running PVC:
1 - How do I make sure I buy the right PVC ?
2 - Can I / should I run it back up the Chiminey ?
3 - If not run back up the Chiminey - is there any thing I need to make sure I do when running PCV? - does the pipe out side need to be a certian hight or do I need to avoid making a bunch of 90 degree turns or anything else I need to worry about ?
sperry is offline   Reply With Quote
Old 08-26-2008, 11:14 PM   #2
Registered User
Termite's Avatar
Typical schedule 40 (drain pipe) PVC is the norm.
Personally, I'd avoid the chimney. The easiest installation is typically horizontal out the side of the house at the rim joist.
All the rest of your questions must be answered by reading the installation manual that came with your furnace. Each and every furnace is different, and venting isn't a standardized practice. You can download it in most cases from the manufacturer's website if you don't have it. Adhere to the size of pipe, length of run, number of elbows, and termination dimensions that they give...All are very important to good performance and safety.
Old 08-27-2008, 07:33 AM   #3
Where to find manual
I looked on-line for an installation manual for this furnace (Armstrong EG6H80DC14 - Ultra 90 III) but no can find. Any ideas ?
Old 08-27-2008, 09:54 AM   #4
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
Here is a set of furnace instructions I found. The general information is there.
http://www.transtaracsupply.com/pdf/...stallation.pdf
I used a concentric vent on my furnace.
http://www.alpinehomeair.com/viewcat...categoryID/346
comp1911 is offline   Reply With Quote
Old 08-27-2008, 11:32 AM   #5
Registered User
Termite's Avatar
Did you try the manufacturer's website? They normally have them in PDF format.
Goodman GMP100-3 Forced air furnace sylvia HVAC 23 12-18-2011 10:49 AM
Need Luxaire Forced Air Furnace Wiring Diagram misticvillage HVAC 7 04-15-2009 05:09 AM
Furnace advice - adding a wood burner to forced air CowboyAndy HVAC 4 03-03-2008 11:21 AM
Goodman GMP100-3 Forced Air Furnace Will Not Ignite Meerkat HVAC 4 02-05-2008 09:44 PM
Oil burning forced air furnace.... good bad or ugly? moneymgmt HVAC 2 06-21-2007 12:01 AM
