Best Way To Patch A Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 04-24-2007, 11:29 AM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 508
Best way to patch a duct
I need to remove an outlet from the big main heating duct (don't know what its called) out of my furnace. There is a large square hole now. Whats the best way to patch this?
J187 is offline   Reply With Quote
Old 04-24-2007, 02:00 PM   #2
Rewards Points: 1,088
Cut a piece of ducting sheetmetal that's slightly larger than the square hole. Secure it into place using sheetmetal screws. Use ducting tape to seal the seams.
handy man88 is offline   Reply With Quote
Old 04-24-2007, 02:15 PM   #3
J187's Avatar
Rewards Points: 508
That was my intuitive thought, but I wasn't sure if maybe there was something I hadn't considered. Thanks a lot.
Old 04-24-2007, 02:21 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
If you really want to be particular, you can also use duct caulking sealer and the foil-style duct tape....
- Build Well -
Old 04-24-2007, 02:45 PM   #5
Yes, you can use mastic, but the ducting tape (not duct tape) should suffice, especially for a home application on a flat surface. Mastic is typically used on ducting joints where there may be more expansion and contraction due to temperature deltas when the heat kicks in.
http://amconservationgroup.com/catalog.aspx?catid=246
Old 04-25-2007, 01:51 PM   #6
Diesel Fitter
Rewards Points: 150
Clean the duct well and let it dry then a bead of sealant,metal patch,screws,and foil tape.
mikemy6 is offline   Reply With Quote
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 10:35 AM
1000-1400cfm...duct sizing Swordfish215 HVAC 1 01-15-2007 04:22 PM
duct sizing Stu HVAC 2 12-22-2006 06:36 PM
Can I use duct tape? Dusty HVAC 2 09-27-2006 09:28 PM
