Best Way To Heat An Attached Shop - HVAC - DIY Chatroom Home Improvement Forum
Old 11-13-2010, 07:16 PM   #1
Best way to heat an attached shop
I have a 14x22x8 foot shop that is unheated at the present time. I have had an old Warm Morning wood and coal stove. However this is no longer acceptable.
I have 2 Brittany Spanial dogs that need to have a warm place in the winter. What is the best way to heat this space that would be safe for both the dogs and us? I do have gas piped to this shop as well as its own electrical service. The shop is insulated and sheetrocked.
Old Timer-1029 is offline   Reply With Quote
Old 11-14-2010, 05:36 AM   #2
An old Tradesmen
Rewards Points: 7,816
Hotdawg heater by Modine.
http://www.modine.com/v2portal/page/...ontent_013.htm
The Following User Says Thank You to beenthere For This Useful Post:
Old Timer-1029 (11-14-2010)
Old 11-14-2010, 09:31 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 148
The "dawgs" will love it. And be hot. Couldn't resist
The Following User Says Thank You to yuri For This Useful Post:
Old 11-14-2010, 11:09 AM   #4
An old Tradesmen
Put your buns away.
Old 11-14-2010, 12:37 PM   #5
Expensive Modine Gas shop heater
Thanks but I was hoping to spend $300-$400 to just keep the chill off. Maybe 50 degrees or so. I think I want gas simply because it won't break the bank. The Modine units are great but extremely pricey.
Old 11-14-2010, 01:05 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 148
Not sure how these compare in price to the Modines but they are very well built and work well. You got to spend some serious $$ once or just use an electric construction heater which is expensive to run and not the safest idea in the long run. The heater adds resale value to the house/garage and all guys want one.
http://www.lennox.com/products/garage-heaters/LF24/
Old 11-14-2010, 02:13 PM   #7
An old Tradesmen
Buy a couple 200 watt IR lights and use them. Put their beds under the lights. The dogs will know where the heat is.
Old Timer-1029 (11-24-2010)
Old 11-24-2010, 08:33 AM   #8
Heat lamps
Sometimes the simplest ideas are the best. I installed 2 250 watt heat lamps pointed at their doghouses. I turn them on for an hour before bedtime and the shop stays at 50 to 55 degrees through the night. Thank you all so much for your ideas. I will be installing the Mr. Heater radiant gas heater next week to take care of our -20 to -30 degree nights coming up.
Old 11-24-2010, 05:21 PM   #9
An old Tradesmen
Glad its working good for you..
Old 11-24-2010, 08:50 PM   #10
Hvac Pro
yuri's Avatar
Rewards Points: 148
One of my customers has 5 full grown St.Bernards. Couple of straw bales and heat lamps is all those dogs want even in the coldest weather. They snuggle and keep each other warm. Big male is 180 lbs. Could pull a wagon with that team.
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
New Heat Pump..questions? ddave23 HVAC 4 03-05-2010 05:13 AM
Heat pump vs in floor heat mugen HVAC 5 03-02-2010 08:18 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 06:15 AM
Programmable thermostats, heat pumps and aux heat Crunkleton HVAC 3 04-21-2009 05:17 PM
