Best Tool For Cutting Into HVAC Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 12-20-2011, 08:53 AM   #1
This is one of those simple questions only experience can answer. I have installed the registers and ducts in the ceiling of a bedroom I am finishing in the basement and now ready to do the final part, cut into the existing out and return ducts. Simply put, I want to make two circular holes into it. Now, I have not done this before and I don't see myself doing it more than a few more times so whatever I use either should have multiple uses or be cheap.
I currently own the usual skill saws, sawszall, 3.6 CFM compressor.
The various tools I have seen described for this purpose range from using a metal blade in the skill saw, right or left angled handheld metal cutters, a dremel type tool with metal cutting tip, 18 gauge metal shear ($32), 14 gauge swivel head metal shear ($50), Harbor freight cheap electric high speed metal saw ($20), or an air shear (my compressor can handle this but not a nibbler).
Just too many choices here!
Sent from my iPad using DIY Forum
MikeInDetroit is offline   Reply With Quote
Old 12-20-2011, 09:01 AM   #2
DIY staff
Rewards Points: 7,174
An ordinary wood chisel and a hammer----if the ducts are secure and the tapping won't knock them loose.
I own a nibbler--shears and the whole nine yards----for one job---use a sharp wood chisel.
Old 12-20-2011, 09:01 AM   #3
Experienced
Jackofall1's Avatar
Mark the hole you want, with a flat head screw driver on its edge start about an inch inside the hole marking and hit the screw driver shaft on an angle so it cuts into the duct to make a slit, then with either green handle (left handed) or red handle (right handed) aviation snips cut the hole along your mark. Snips are less the $20 and is the best way to cut the holes.
Mark
The Following 2 Users Say Thank You to Jackofall1 For This Useful Post:
oh'mike (12-20-2011), VIPlumber (12-21-2011)
Old 12-20-2011, 05:03 PM   #4
Rewards Points: 1,216
Mark
I second that.
COLDIRON is offline   Reply With Quote
Old 12-20-2011, 08:23 PM   #5
REP
If you are going to use it in the future,I used a Malco tool HC-1
Once you get used to it you can cut dozens of holes an hour.
REP is offline   Reply With Quote
The Following User Says Thank You to REP For This Useful Post:
ben's plumbing (12-20-2011)
Old 12-21-2011, 08:05 PM   #6
Thank you gentlemen. The snips it is. Oh and I do agree that malco is the exact tool for the job but I know I'll need the snips for other things in the future.
Sealing air return duct jd1979 HVAC 8 10-07-2010 07:46 PM
ECO / green options for insulating HVAC duct work ACtawk HVAC 3 10-03-2010 06:02 PM
Openings in air intake duct on central HVAC system Omegazz HVAC 5 04-01-2010 12:59 PM
Random HVAC duct in garage...help! gone_fishing HVAC 4 07-26-2008 02:04 PM
Heater Return duct - Moved to HVAC forum backpacker2 HVAC 1 05-16-2007 11:30 AM
