Best Thermostat For Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 07-11-2011, 07:15 PM   #1
Best Thermostat for heat pump
what is the best thermostat to buy for a heat pump system. My Honeywell 7 day thermostat seems to go on so often and turns on before the temperature even drops.
lynkidd is offline   Reply With Quote
Old 07-12-2011, 10:30 AM   #2
Rewards Points: 392
I got my vision pro thermostat 8000 configured so it comes on every 45 to 60 minutes.. That is one of my complaints though too.. I'd like the ability to set it longer or widen the temp range of the control loop.. How often does yours cycle?
zootjeff is offline   Reply With Quote
Old 07-12-2011, 05:04 PM   #3
An old Tradesmen
Rewards Points: 6,870
A comfort thermostat is a very tight temp control device. So you won't see the temp drop.
White Rodgers makes thermostats that have a temp differential you can slightly adjust.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
carrier infinity 50Xt packaged heat pump with infinity thermostat mguillen HVAC 12 12-05-2011 01:42 PM
heat pump wiring problem - new thermostat tygrr94 HVAC 8 01-17-2011 08:18 PM
Hunter Thermostat Model 44860 Heat Pump Emergency Heat Does Not Work On Auto stvnhdmpa HVAC 8 12-08-2010 05:44 PM
An efficient programmable thermostat for a heat pump? mow2000 HVAC 17 01-16-2010 08:09 PM
