Best Radiant Heating (probably Under Carpet) - HVAC - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 01:32 AM   #1
Best Radiant Heating (probably under carpet)
Hey all,
Bought a house in November, master bedroom is an addition with a crawl space underneath. Very cold room, almost 10 degrees colder than the rest of the house I think. Wanted to heat the crawl space, had the HVAC guy out today, the joists are staggered between the original house and the addition so he cannot insert lines into the crawl space. So, now we are at the point of looking at insulating the joists under the floor and adding radiant heat, probably over new carpet. Was wondering what brands and types available to Canadians you would all suggest (located in Edmonton, it was -40C with wind chill here all week, you can see why I want this sorted out).
Thanks a bunch.
BeMurda is offline   Reply With Quote
Old 01-21-2012, 05:53 AM   #2
biggles's Avatar
might need to do all the insulating above the floor and minimal styrafoam sheets or spray foam in the crawl space the trick is to seal the heat in the room.they have electric floor heat with flooring going over it and it maintains the room.don't knoe about doing it over or under carpeting might have to loose the rug...check YOUTUBE for installation videos here is one..
Installing radiant heating in a basement and general basement questions... CarlsonRower General DIY Discussions 6 12-09-2011 01:32 AM
Radiant floor heating system has major leak, need to replace hoekzebs HVAC 3 03-29-2011 04:18 PM
Considering Radiant Heating acerunner Remodeling 4 07-03-2010 03:17 AM
Radiant floor heating questions secutanudu HVAC 35 03-08-2010 02:04 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
